Remove scratch
Old Oct 8, 2017 | 07:55 PM
Bruze's Avatar
Bruze
Originally Posted by kliph
Plan A..didn't work.
Plan B..didn't work.
Plan C..is next. If that doesn't work than it's to...
Plan D..body repair man.
Good luck, keep us posted.
It won't be cheap, depending on what exactly needs to be done. What color is it? Is it a tintcoat?
Old Oct 9, 2017 | 08:44 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by irok
12 hours of wet sanding and polishing later the 24" scratch that painters said couldn't be repaired was as new
At the cost of the majority of the clear coat on that section.
Old Oct 9, 2017 | 10:03 AM
dryadsdad's Avatar
dryadsdad
Hair of the dog....
Kill and skin dog. Use its hair to polish the scratch using Dupont 7 polish. Then take the car to a body shop for a respray.
This will not only remove the scratch but prevent new scratches.
Old Oct 9, 2017 | 05:38 PM
irok's Avatar
irok
the repair was done about 5 years ago with 3000 grit and clear coat is as new at no cost to me.hard to better those results except maybe by one of the old hens
Old Oct 10, 2017 | 09:44 PM
kliph's Avatar
kliph
OK, plan C 1. This whole thing is screwing up my plan.
The plan was to put the car in storage until spring.
At that time the battery would be 8 years old.
I would change the battery when I pick up the car.
I thought it was a perfect plan. So much for thinking.
Now the plan is to clean the car and put it in storage.
And take care of it in the spring.
PS. I may jump right to plan D in the spring.
I have a friend who owns a car repair business,
I will ask him about it. (I was out to dinner with him, and others,
over the weekend and forgot to ask.)
Old Oct 11, 2017 | 12:07 AM
Signal_20's Avatar
Signal_20
Originally Posted by dryadsdad
Hair of the dog....
I am still laughing from this thanks.
Jim
Old Oct 11, 2017 | 06:32 AM
RobLo's Avatar
RobLo
My car had some fingernail-catching scratches on the door and fender from the previous owner. I took it to a local pinstriper who touched up the paint, sanded, filled again, polished and finished with clear coat. It took about 2 hours, charge was $120, I gave him $150. I also had a small pipe ding the front fender on the Harley, he mixed up the exact colors (it was right on the pinstripe so there was 2 colors involved) and touched it up and clear coated it, the ding is still there but hardly noticeable, charge $60. I cringed watching him take the buffer wheel to both vehicles but they both came out perfect. A good detailer should do the trick...good luck!
Old Oct 11, 2017 | 07:40 AM
EVILFACE's Avatar
EVILFACE
Originally Posted by owc6
Unfortunately, if a pro detailer can't get it out, then you can either:
1: Live with it.
2: Take it to a body shop.
3: Don't look at it.
Old Oct 11, 2017 | 08:43 PM
owc6's Avatar
owc6
3: is the only way to 1:
Old Oct 24, 2017 | 08:59 PM
kliph's Avatar
kliph
Done!
Took the car to Buffalo Car Care. (BCC) http://www.bccdetailing.com/.
Detailed inside and out. Scratches are gone.
I just couldn't wait until spring to get it done.
Thinking about it all winter would drive me nuts.
The car looks great.
Of course it rained on the way home.
A black car is beautiful when it's clean, but when it's dirty it's bad!
I will disconnect the battery(https://www.corvetteforum.com/forums...ovable-gs.html) and do what needs to be done waiting until spring.
But I will clean it up and put it in storage this week.
Thanks for the input.
Kliph
PS. Cost $700+
Old Oct 24, 2017 | 09:36 PM
Bruze's Avatar
Bruze
Done!
Kliph
PS. Cost $700+
Good to hear!
You lucked out that the scratches weren't too deep to remove.
We could have a few weeks left til the salt trucks come out; I'm not putting mine away yet.
Old Oct 27, 2017 | 01:03 AM
Jaydubgt's Avatar
Jaydubgt
Originally Posted by Johnathon59
I had that exact thing happen to my car, I used "Meguiar's Scratch X20" worked great took out the scratches & then I used some polish compound to get the gloss back...
As close as there is to a 'miracle' scratch remover that I've found. It gets out scratches that I thought were permanent.
