Question re: jacking up my C6
This may be a dumb question to some, but here goes. It's been many many moons since I've used a jack on a vehicle.
I've had the car for about three years and now would like to use my new low-profile Pittsburgh Automotive low-profile jack to lift it, from the front end, to allow me easier access to the fog lamp receptacles. I have pucks to use in conjunction with the jack, and also have a pair of good quality jack stands.
Question is this: If I jack up my '08 car at the location on the front driver's side, do I jack it up enough so that the entire front end of the vehicle comes off the ground (i.e. so that I can deploy both jack stands under the front of vehicle in this one jacking operation); or do I need to do two separate jacking operations (putting one jack stand under the front driver's side, lowering the car onto that jack stand, then jacking up the vehicle from the front passenger side to place the second jack stand)? The owner's manual ain't clear on this point.
Thanks to all,
Bo
Thanks to all,
Bo
If you jack it up from the jacking points on each side of the car, you won't be able to lift the whole front end at one time. It will raise the side of the car you are jacking more than the front of the car, so you will have to do each side one at a time.
Ajaste (11-26-2017)
Received 3,088 Likes
2021 C6 of the Year Finalist - Modified
The good news about that Pittsburgh low profile / long reach jack is that this particular jack is certainly low enough to be pushed under the center / front of the C6, and then be placed under the aluminum cross member of the car.
However, the problem is ... even though the jack has a very long handle, the handle is not long enough to jack the front of the car up since the nose of the car is so low (no room for the jack's handle to go up and down)
You either need to drive the front wheels up on some wood before placeing your Pittsburgh jack, or get another jack and lift at least one side of the car up a little from the front / side jacking point in order to have enough room to place that Pittsburgh jack in front and still be able to raise the car using the Pittsburgh's long handle.
It's all just a big pain in the *** !
Good luck !
Good luck !
Ajaste (11-26-2017)
You either need to drive the front wheels up on some wood before placeing your Pittsburgh jack, or get another jack and lift at least one side of the car up a little from the side jacking point in order to have enough room to place that Pittsburgh jack in front and still be able to raise the car using the Pittsburgh's long handle.
Good luck !
Good luck !
I agree it is a pain, I put together two 2x4s to drive up on so that I had room to use the jack handle. I keep them close since I use them frequently.
The following 2 users liked this post by Andy05C6:
Ajaste (11-26-2017),
RogerRamjet21 (02-16-2018)
Just jack up each side - it will be up & on the stands in less than 5 mins start to finish
If you want to raise the stands up below 1 or 2 clicks I always do it in 2 steps to keep the left to right angles to a minumum
Ajaste (11-26-2017)
Ajaste (11-27-2017)
This is what I do, and why I have two HF race jacks; one for each side. Pump one side up a few times, walk to other side and do the same. Rinse, repeat until car is high enough to put jack stands underneath. I can have all four corners up in the air in a matter of minutes.
Ajaste (11-27-2017)
Okay, I have used the blue points to jack one side of the front of the car so I could do some work on the bumper cover. Since I wasn't under the car, I didn't use a jack stand. If jacking the car at the blue lift point, where do you place a jack stand?
Simple answer, at the red spot.
Complex answer, the best way to get the car in the air is to lift the entire front end at the red spots and place the jack stands at the blue spots. The car is very stable. I made a beam out of 2x4" metal "tubing" (actually looks like a 2x4 piece of wood) to span the red areas on the aluminum subframes. To get the car high enough in the air for use of the jack, I use a pair of Race Ramps.
The 2x4 tubing is long enough where I can place jack stands under it at that the endpoints and remove the jack and have at times supported the car both front and read on two pieces of tubing. I don't recommend doing this as the width of the base isn't wide enough for stability. You could, however, support the front (or rear) at the red spots using the tubing, and support the opposite end at the blue spots.
The following 2 users liked this post by mikeCsix:
GHOLD (02-16-2018),
Using the red point on the frame requires the car to be lifted 3’’ To get a jack with lifting beam under the car.
I back my car up on four 3’’ Race ramps,( one ramp per wheel) and then jack it up using a jacking beam, 10 minuets and its up 12’’ on stands.
I made two beams out of 100x50x4 RHS.
mikeCsix Is correct make sure you support the car at the blue points. For safe reasons.
+100 I've got the 2-pc race ramps which are fine for oil changes and anything that doesn't require removing a wheel, but if I ever contemplate doing anything that needs removing the wheels, Quick Jack it will be.
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
I use a system similar to some of the above. I drive the car onto 2 x 12 lift ramps that I build (or RaceRamps) then place my jack under the center of a wood cradle I built and raise the front enough to place jackstands under each end of the cradle. This protects the aluminum crossmember from being damaged by the jackstand. I then do the same at the rear. The Corvette is now level for efficient oil drainage, etc.
These photos were taken under our previous C5, but I still use the same pieces and technique with the C6.
It can be done with one jacking operation (at the blue jack point) if your jack can lift 18-19" high. That is what I do when I parked close to the side wall, otherwise I will use 2 jacks on both sides.
I have also seen metal tubing cradles or crossbars that attach to certain brands of floor-jacks, but the wood is less expensive and, I think it makes for a more stable base.
GHOLD (02-17-2018)
duckvett (02-18-2018)
I always found it really easy and convenient to pull into a Firestone and let them to it. Maybe I’d rather drive than lie on a gravel driveway.
