Polishing
Spend some time just watching the Autogeek videos, and as others have said - go slow and let the machine do the work.
Three other pieces of advice....
1) Step one - wash the car to remove all dirt.
2) After washing the car once - wash it a second time with a cleaner that will remove the old waxes / "sealants" that you have on the car. Normally - we don't want to hurt the wax on the car when we wash it - but if you are going to be working on the clearcoat - you don't want any old wax on there. Rinse THOROUGHLY !!!!
3) When deciding how aggressive a compound to use - it's better to take a chance with too mild a compound and realize that it didn't do what you needed it to than to initially go with something too aggressive. For a pro - where time is money - they can't take too much time to do a car - but for a DIY'er - it's better to be conservative.
I've (successfully) used a rotary buffer, and while I'm not even close to being "good" with them - it is truly amazing what they can do !!! But with the old wool pads - they could also ruin a finish in a heartbeat. Today - with the foam pads - even amateurs can use the big rotary buffers "relatively safely" - but from where I'm sitting the only real advantages the rotary buffers have over the DA's is speed, and their ability to deal with major paint defects. So - from a DIY perspective - I would stick with a DA on a vehicle you care about. If you want to play with a rotary buffer - GREAT - but learn / practice on a vehicle that you don't care about, or on a panel that is going to be repainted anyway. If you stick to relatively mild compounds with a DA let the machine do the work and respect edges - it's hard to screw things up.
QUESTION for grzldvt1 - What is your opinion of the Lake Country pads vs. the Rupes pads for a DA???
sounds like the polisher is pretty safe for a novice. Might not get the bad scratches but should work on the water makes and light scratches. It will give me something to do and learn a little. From what I’ve read it’s a slow process if done correctly.
As others have mentioned, it is a multi-step process but if you take the time to do it right, then you just have to maintain it after that and you don't need to keep doing it. Do it out of direct sunlight when the temperature is moderate.
1. wash
2. clay bar or nano skin - removes embedded debris
3. compound - removes swirls and scratches in clearcoat
4. polish - fine finishing for a great reflecting shine
5. sealant or wax - protect against oxidation, weather etc.
I use Wolfgang products and Lake Country pads
I could go into a PH.D dissertation. Bottom line you need to do a little experimentation on the speed, with your product and pad.
However these simply kick butt when removing the ugly stuff to medium scratches/swirlsMeguiar's Cutting Pads
I have been able to create stunning results, NOT just OK, or excellent, but stunning results with these pads. I have not come across, and darlinks we experiment with a lot of pads, anything that is so flexible with various compounds.
Does that help or confuse?
THANK YOU !!! It Helps !!! I'm an amateur, but I do like to try to keep the finish on my toys looking good. Most of the time that means just getting it good - then taking care of it - but sometimes you need to go back and clean up some problems that the roads have created....
I have been using the Lake Country pads for a while, and I'm quite happy with them. I have also used the Meguiars foam pads with rotary (for doing some large panels) - but with very gentle compounds, and have been happy with them as well.
Again - THANK YOU for your input !!!!
1. wash
I can't even get past step one! The damn water hose is frozen solid. My polisher and stuff came in last night and I am anxious to get started but it's probably too cold as my shop is not heated.
Seriously, I've never heard of that....so I googled it. Interesting.
I think I'd still like to rinse off with water. A cat walked across the hood and left muddy paw prints! IKR! I was ready to kill the cat. Anyway, I want to hose it off before I use any rag or sponge.
https://www.amazon.com/Nanoskin-AS-0...skin+autoscrub
nSF
As a pro detailer I am always looking for the best, while good, not as much old school as one would believe.
I also 2nd the recommendation on Adams Polishes. Their Waterless Wash product is great. Follow the instructions and have just when you think you have enough microfiber towels, buy MORE.
And speaking of microfiber towels, don't buy the cheap ones like I did thinking you'll save $$. I now use the "cheapies" like a paper towel and throw them out after a single use.
When using a clay bar/mit/towel, etc, I don't think you can have too much lubricant.
