Calipers
Old Jan 3, 2018 | 09:05 PM
StrykerZ06's Avatar
StrykerZ06
Default Calipers
Ready to pull the Calipers off my C6 2010 Grand Sport. Tonight the bolts got their first blast of WD40. Giving them another shot tomorrow. Question is what is the best tool to remove the bolts? Impact wrench too much? Do I need to nurse them loose with a breaker bar? They have to come off as I'm Powder Coating them.
Thanks in advance
Old Jan 3, 2018 | 09:35 PM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
I used a breaker bar on mine. 129 ft lbs but you can do it. I shot mine with Kroil , and let it sit overnight. Did all four calipers, came off without much of a fight.
Old Jan 3, 2018 | 09:38 PM
Lee Cromwell's Avatar
Lee Cromwell
They come right off, no biggie, simple hand tools.
Old Jan 3, 2018 | 11:41 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
mine came right off
Old Jan 4, 2018 | 01:39 AM
Mlcharlestonsc's Avatar
Mlcharlestonsc
When getting powdered do you need to pull the Pistons out and strip down, then rebuild them?
Old Jan 4, 2018 | 05:26 AM
StrykerZ06's Avatar
StrykerZ06
Default Powder Coating
Short answer is yes. I bought new rebuild kits and brake lines since I'm tearing everything down.
Old Jan 4, 2018 | 01:18 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I have never had to soak any caliper bolts on any Vette I have done brakes on, including my 78. A 2010 shouldn't need anything more than a set of muscles with a breaker bar.
Old Jan 4, 2018 | 01:25 PM
Corvette_Ed's Avatar
Corvette_Ed
Depends on the car. I fought the rear calipers on my C5 for two days before finally getting both broken loose. I'd have killed for an impact wrench.
Old Jan 4, 2018 | 02:05 PM
Bob Paris's Avatar
Bob Paris
I used a large ratchet wrench, hanging down, that I repeatedly hit with a sledge hammer. Used Loctite blue when I reattached.
Old Jan 4, 2018 | 02:40 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
wait..... you talking about the caliper bolts? or the caliper mounting bracket bolts?
you shouldn't need anything more than a 3/8 drive socket wrench and an open end wrench for the caliper bolts.
Old Jan 4, 2018 | 02:53 PM
Bob Paris's Avatar
Bob Paris
OP stated: "Ready to pull the Calipers off my C6 2010 Grand Sport." I took that to mean the caliper mounting bracket bolts.
Old Jan 4, 2018 | 03:04 PM
RPOZ4Z's Avatar
RPOZ4Z
I took it literally... because you don't need to remove the caliper mounting brackets to remove the calipers.
you don't even need to remove the calipers to change brake pads!
Old Jan 4, 2018 | 04:40 PM
mikeCsix's Avatar
mikeCsix
Aero Kroil is really good oil for loosening frozen parts. WD-40 is good for a lot of things, but loosening rusted bolts isn't one of them.
Old Jan 4, 2018 | 11:49 PM
buckmeister2's Avatar
buckmeister2
Absolutely correct. WD is good rust-preventative. It is NOT a good penetrating oil, nor a good lubricant.
Old Jan 5, 2018 | 04:00 AM
Bob Paris's Avatar
Bob Paris
WD-40 is also not a good marinade. Ask me how I know...
Old Jan 5, 2018 | 08:33 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
If you are changing pads you need to either have the rotors turned or replaced. In that case you need to remove the caliper to mounting bracket bolts to remove the caliper to enable removal of the rotor. Those bolts do require some effort to remove them. If you remove the caliper their is no need to remove the brake padlet retaining bolts because you can insert the padlet from the bottom of the caliper. After removing the master cylinder I was able to easily push the pistons back in by hand.
Old Jan 5, 2018 | 01:57 PM
buckmeister2
Bob, that is a story that needs to be told...
Old Jan 5, 2018 | 06:21 PM
mikeCsix's Avatar
mikeCsix
one unintended application for WD-40 is adhesive remover for baked on masking tape and labels.
Foe marinade, sounds like Bob has an interesting story to tell...
To Calipers
