Hi beam update
Former Vendor
If you don't install dust caps, perhaps then you may get some dust in there, but I'd suggest installing the dust caps.
Our product (SL1) was designed to fit with the factory dust caps installed.
Thanks!
Nick C.
2008 Corvette (01-26-2018)
Haven't seen any threads on C6 hi beam LED in a while. Anyone have success with an LED replacement in the Hi Beam position?
I did some LED fog replacement from Diode Dynamics and they are great. They do not suggest a hi beam led though.
There are lots of cheap stuff on ebay and amazon that I'm really not interested in.
Currently have an HID setup from Corvette Mods but really never liked it. Too bluish.
I'm thinking something in the 5000K range.
Any thoughts? I do live where bright lights can be used.
for your HID low beams you want 4300K.... they start to get blue when you get above 5000K and the light output also goes down.. if you actually drive your car at night and want to see what's in front of you don't go any higher than 4300K HID lowbeams.
Former Vendor
While they produce the same amount of lumen output, 4300K will produce more visible output. Those differences between 4300K/5000K/6000K are minimal.
8000K+ though will definitely have a major impact on output. I wouldn't recommend anything beyond 8000K.
Thank you!
Nick C.
Since this thread is in the front page, I thought I'd ask what vendors forum members recommend for updating the exterior lighting on my C6.
I'm mostly looking to update my headlights (DRLs, low beam, high beam) and reverse light.
I've been eyeing Radio Flyer Innovations' website and my total comes up to $450, including the following:
Many thanks!
- DRL LED Switchbacks (white LED DRL, amber LED turn signal/hazards)
- Higher ouput HID low beam
- LED High beam
- LED reverse lights
- Plug and play harnesses (necessary, I'm not the best with soldering)
Many thanks!
kevinjm (01-26-2018)
Nick,
Thank you for weighing in on this thread and the H9 now being available where before it was not. If we look at the Lumen output of 1630 that seems low when compared to other manufacturers. We do understand that the marketing behind these type of bulbs are all over the place. It is easier to say mine is bigger than yours when you don't have each side by side for comparison. I personally have your bulbs in my fogs and they changed the whole dynamic of driving at night.
Do not want to start a Lumen rating war here but as a forum vendor could you take a moment to expand on how you rate your bulbs and arrive at those brightness numbers?
4300K is indeed the OEM color temperature, and ideal for low-beam use. However, 5000K is pure white with no hint of color, and true 6000K actually has very little blue at all.
Thank you!
Nick C.
Thank you!
Nick C.
#33
Former Vendor
Nick,
It's important to note that our lumen numbers are actual, real-world, in-house measurements. 99% of lighting vendors offering imported products are relying on overseas manufacturers to provide them with lumen numbers, which are almost always completely fake, or theoretical. You should avoid products with rounded lumen numbers like 8000, 10000+ as it's completely fictitious and not possible.
Compare it to a company selling intakes and claiming gains of 500+ hp by adding an intake. That's essentially what our lumen numbers are going up against marketing-wise.
Our engineering team measures everything in-house, here's an example of that process:
Another thing to keep in mind with regards to lumens, how is this output being directed & focused? You could have an incredibly high lumen total, but if that output isn't focused correctly, it's not going to be useful as say, a 1,630 lumen option that creates the same pattern as an OEM bulb and focuses the light better.
Our SL1 performs extremely well, and was designed to have an extremely long lifespan. At 1,630 lumens (more than a comparable halogen bulb), it's focused nicely and will create more usable output than other market options.
We will have a lot more information available on the SL1s soon, they were finally released in Nov. 2017 after 2+ years of R&D, engineering, and production tooling.
Thank you!
Nick C.
#34
Well the link shows 6/8 week delivery and if you go to their website directly shows out of stock.
Anyone manage to get a pair to try yet? I would probably give them a shot if they were ever available.
#35
Former Vendor
They've done extremely well for us, and our customers have sent in some great output photos.
The SL1 works best in reflector style housings. With all this being said, if anyone with a C6 lives here in St. Louis, please give us a call: (314) 205-3033
We would love to bring one into the studio for comparison photos and installation videos!
Nick C.
#39
The problem is two-fold, made in China and most likely not the correct focal length for the reflector meaning it would be no different than adding hid's to a halogen reflector. Sure the light is brighter but since it is more scattered, it isn't as useable (and oncoming traffic can be blinded).
#40
Just about everything is made in China (or Mexico) now, but at least jdmastar is based in LA and has real live people in LA to take your call and answer questions.
