Bluetooth question
Old Feb 6, 2018 | 05:44 PM
tsmart's Avatar
tsmart
Default Bluetooth question
My phone says its connected to the car , car says its connected to the phone, but I cant play pandora music, is this feature only for phone calls? Or am i missing something? I can use aux cable from phone, that works...
Old Feb 6, 2018 | 06:45 PM
ByRiver's Avatar
ByRiver
Phone calls only using Bluetooth. No streaming audio on the C6. You will have to either use your AUX cable or install a streaming audio dongle of some sort. Do a search for what others have done.
I have a USB port on my '12, so I put my music on a 16Gb thumb drive. Far easier than messing around with a phone to stream music. And very easy to update with new tunes. Again, far easier than messing around with a phone and making sure it is charged.
Old Feb 6, 2018 | 07:18 PM
LowRyter's Avatar
LowRyter
I use this. They're $5 now
I can answer the phone and use the phone to toggle music and hear directions.
Old Feb 6, 2018 | 07:58 PM
tsmart's Avatar
tsmart
That .would work, where can i get one??
Old Feb 6, 2018 | 10:30 PM
LowRyter's Avatar
LowRyter
Mrs Google or Mr Amazon.
Old Feb 7, 2018 | 12:06 PM
ben z's Avatar
ben z
I had no idea the later C6 BT doesn't support streaming! Mine came with an aftermarket head unit, probably would have gone that route myself rather than fiddling with a 3.5mm dongle (they need to be recharged like an earpiece, unless you get an iSimple which can be hardwired to power).
For me it's not just music, I use it to stream GPS voice commands. In fact a use streaming a lot more than phone.
Old Feb 7, 2018 | 03:53 PM
LowRyter's Avatar
LowRyter
bz- It takes about an hour to charge one up for 8 hours of use. So you can charge it while you stop for lunch and of course you can always charge it while you are using it. You can purchase two for $10 and keep one charged in the console.
What I like about it: you keep the car completely stock, you can answer the phone with the toggle and talk thru the mic, you can toggle your music back and forward, and listen to directions programmed on your phone.
If you want to see a map, I recommend one of those phone caddies that stick in the CD slot. Then you have the option of direct wire instead of blue tooth.
Old Feb 8, 2018 | 11:34 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
NCCC Lifetime Member
I just use the Aux-in. I plug one cable into phone via the lightening cable that carries both power and audio. Since I like to plug in power anyway it's not a big deal to have the aux cable too.
Old Feb 9, 2018 | 03:47 AM
Dano523's Avatar
Dano523
Later model vets (2009 and forward) blue tooth device is in the VCIM module, hence piggy backs off the ONSTAR module to use that module for the calls.
If you want to pipe the Iphone/ipad into the OEM Nav radio for music on 2011 and later models , then you use the USB aux port in the back of the center console instead. This not only pipes the ipad/Iphone in, but gives you control over the Iphone/ipad on the radio controls as well.
Old Feb 19, 2018 | 12:16 PM
tsmart's Avatar
tsmart
I found this product at walmart, $5, but NOT in electronics. They knew nothing about it. While in check out line, there they were with cheapo ear buds and cell phone covers. Installed in Vette, works perfectly.
Old Feb 19, 2018 | 01:49 PM
GRCTampa's Avatar
GRCTampa
Could you confirm the year this USB aux port was introduced? I do not have this org in my 2011 Base 2 LT coupe. Thanks.
Old Feb 19, 2018 | 02:05 PM
Frankie15's Avatar
Frankie15
It only came on the 2011+ models that had the navigation option. I retrofitted this (along with supporting hardware) in my 08.
Old Feb 19, 2018 | 03:19 PM
LowRyter's Avatar
LowRyter
tolda ya!
ha, saved ya $700 for a new radio and you're still OEM.
To Bluetooth question
