replace your cabin air filters!
been lurking the forums here. i bought a genuine one from Adelco on my base 2008. my old one was like black and deformed in a way. new one is so fresh. cheap and easy. its for sure worth it to change once per year
Sunnyvale Dave (07-07-2018)
St. Jude Donor '08
Welcome to the forum. This subject has been talked about in numerous posts. Take some time using the search functions, as you will very often find the answer to your questions without even asking.
Usually a first time poster asks how much does it cost and should I have the dealer do it??
Bruze (07-06-2018)
I just put the top down, and the cabin filter is a very small concern.
yes -- and Tim Allen once told me if you re-wire that Fan motor to rum Bi-Directional -- when the top is down - reverse the motor direction so it reverses the air flow thru the filter so you can get 60K miles out of her..
Received 3,095 Likes
2021 C6 of the Year Finalist - Modified
I just washed the charcoal cabin air filter...it worked fine. Dried it in the sun, and voila...like new! The filter was fine and dandy.
Received 3,738 Likes
2016 C6 of Year Finalist
kronix (07-08-2018)
Received 4,527 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I replace every other year!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I just discovered that Pep Boys doesn't carry the Purolator filter anymore. They used to have a good deal of ordering online and picking up in the store.
I am confused as to the difference between ACDelco Professional and OEM.
