New head unit?
#42
AVIC8201NEX with RP5-GM11
Startup yes as RedFred say's. My Radio is on within 5 seconds. Navigation takes a little bit. I have three factory Nav's Two Chevys and one Dodge Ram they all load the Nav very quickly. The Pioneer can take 10-20 seconds depends if the car is outside or in the garage.
#43
Received 1,636 Likes
And don’t forget to add a nice background. And I don’t mean a picture of your car.
#45
Pioneer Avic8201Nex W/RP5-GM11
Here’s a small video of after the install
sorry for sun refection. My garage faces due west and the car was in the garage. Still gets strong XM and GPS signals
The following 2 users liked this post by jeffs64:
C6Whatever (04-16-2019),
TorchRedFred (08-26-2018)
#46
My start up screen. One good thing about the Pioneer's is that they make it real easy to add a custom background and start up screen.
jeffs64 (08-26-2018)
#47
I use a very similar one. A bit darker with a bit of a carbon fiber look to the background.
https://www.corvetteforum.com/forums...this-first.jpg
#48
#49
The link to the jpeg I posted is the exact file.
#50
I found it in this thread formatted to the right size and ready to go: https://www.corvetteforum.com/forums...up-screen.html
#51
#53
There is a microphone that comes with the 8200. I installed mine right next to the existing mic on the A pillar. With the RP5-GM11 interface and proper setup, steering wheel controls can be maintained. For speakers, the stereo speakers are used, but any music playing will be properly attenuated.
#54
#55
Right. The wire can run under the kick panel on the driver's side and then up into the A pillar behind the trim.
FiveVettes (08-26-2018)
#56
Old unit
New unit
RP5-GM11 Pac Audio Intreface
SVX300v1 XM Tuner
Microphone installed on A Pillar next to OnStar Mic
Backup camera
Here's What you need
about 16-20 # 18 Gauge Butt connectors and two 15" pieces of wire one Yellow and one Black
# 15 Torx Bit
7mm Socket
Old unit out
Double Din Dash Kit
New unit your choice Pioneer (Avic8201Nex) Comes with Back up camera
RP5-GM11 to retain Bose or Non Bose system / OnStar / Steering Wheel Control
Total cost
Head unit $650.00
Double Din Kit $7.95
RP5-GM11 $89.00
XM Tuner $40.00
Total $800.00
Most important three or four hours of time and patients.
If anyone need's any info let me know. PM me
FiveVettes (08-27-2018)
#58
If you look at the Pioneer web site under the fit guide the W8400 does not fit. You will need to remove a plastic mount inside the dash. It’s a square mount that a guide pin that sticks out of the back of the OE headunit. I remove it and added about two of niches of clearance. The cooling fan on the back of the W8400 sticks out about an inch and would hit that mount. So if you remove it you’ll have no problem.
#60
I have had this in my 2011 for about a year and I am very happy with it. I highly recommend having a back up camera which is included with this package.
Good luck, there are any great options. Let your budget narrow down your choices.
