C6 help
Old Nov 4, 2018 | 11:15 AM
granitxpert's Avatar
granitxpert
6th Gear
Default C6 help
I have 2005 c6 all stock with engine codes
p0131, p0137, p0201, and p0301 with metal shavings coming from exhaust and now a knock
Old Nov 4, 2018 | 11:16 AM
Corvette_Ed's Avatar
Corvette_Ed
If you have metal shavings coming out of your exhaust you have some serious issues. I wouldn't run or drive the car.
Old Nov 4, 2018 | 01:46 PM
HBsurfer's Avatar
HBsurfer
Metal shavings in your exhaust is not good. Enter those codes in a Google search and you will find out a little more about what the car is trying to tell you. I would not be driving that car until you know what is going on.
Old Nov 4, 2018 | 03:05 PM
granitxpert
6th Gear
The codes are cylinder 1 injector and bank 1 02 sensors 1and 2
Old Nov 4, 2018 | 08:11 PM
M096865's Avatar
M096865
I would also recommend that you pull the oil into a clean drain pan and inspect it for any metal fines.
You should be able to filter it through cheese cloth or even a couple of coffee filters.
You should also pull the filter and look for metal shavings.
If there is any doubt, I would replace oil and filter and run for short period and drain, inspect, and replace again.
This should at least rule out metal originating from internal engine components.
I just pulled apart my 06 because of a hydrolock event, bought it that way.
One cylinder had bent connecting rod and chucks missing from skirt.
If at any point noise gets worse, stop running engine.
Did something unusual happen or did you crank on it and then noise started?
Old Nov 4, 2018 | 08:18 PM
BackInBlack05's Avatar
BackInBlack05
Exhaust isn't really connected to oil.
Dunno how OP evaluated his exhaust.
I blew chunks out my exhaust once on my 68 Mustang. When I pulled the head you could reach down into the sump as there was no piston, rod, cylinder wall, etc.
Old Nov 4, 2018 | 08:55 PM
M096865's Avatar
M096865
Maybe it is exhaust/injector sensor driven causing knock but it may be coincidental with a more serious engine problem.
I know if I started hearing a significant knock from my engine I would want to try and rule out internal problems before it gets any worse.
Engine may be fine and problem related to something else. I just wouldn't want to find out the hard way while trouble shooting.
Old Nov 5, 2018 | 09:22 AM
granitxpert
6th Gear
Default Re help
car started missing with codes for random misfire so I pulled the spark plugs and replaced them then it started the rattling on deceleration I haven’t ran it sense I’m thinking it’s a valve. I’m gonna drain the oil tonight if it looks good I’m gonna pull the heads I pulled right valve cover and everything looked good so gonna pull left side
Old Nov 5, 2018 | 09:43 AM
Kenny94945's Avatar
Kenny94945
FWIW . Exhaust metal shavings = cat convertor failure. It is coming apart IMO.
Prudent to change motor oil and inspect spark plugs.
Old Nov 5, 2018 | 07:38 PM
granitxpert
6th Gear
I’ve changed plugs the ones I pulled where gone pretty much changed wires everything is firing good now but the code for cylinder 1 injector and both converters on bank 1 had to mean something just not sure about knocking I’m about to drain oil but haven’t started the car since I heard it
Old Nov 5, 2018 | 10:03 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
If it should happen to be a Z51 with metal shavings in the oil remember the shavings are in the lines and cooler.
Old Nov 5, 2018 | 10:44 PM
granitxpert
6th Gear
Oil didn’t look bad at all I’m stumped
Old Nov 5, 2018 | 10:47 PM
ruxvette's Avatar
ruxvette
You pulled both valve covers and both sides looks good?
I would get a stethoscope and try to locate the knock.
Old Nov 5, 2018 | 10:51 PM
mrk1957's Avatar
mrk1957
I agree about a cat failure. Could be why you're getting those codes.
Old Nov 6, 2018 | 12:49 AM
BackInBlack05
My exhaust guy says most cats fail due to misfire and the like. They really don't wear out.
Old Nov 6, 2018 | 10:13 AM
mrk1957's Avatar
mrk1957
I used to think the same, but I've had cats fail. What metal are the shavings? I would think it'd be hard for something from the engine to make its way out the exhaust. Especially the way cats are designed. There's normally fine screens etc. that would catch something like that. If so, wouldn't it be some catastrophic failure in the engine and obvious?
I'd start at the cats and work your way back to the engine.
Old Nov 6, 2018 | 12:50 PM
M096865's Avatar
M096865
If oil looks fine, as suggested you can definitely hear internal engine issues to better isolate with a mechanics stethoscope.
You can get one for 8 bucks at harbor freight.
Just used one to find which cylinder was bad in my c6 from a hydrolock event.
One cylinder was clearly louder than the rest.
This was not detectable by ear only.
Old Nov 6, 2018 | 04:11 PM
granitxpert
6th Gear
Oil was clean and looks like goldish shavings so I’m betting converter is bad and last night i noticed there was a small puddle around one injector I’m hopeful that this explains my problems
Old Nov 7, 2018 | 08:01 PM
Gman in NC's Avatar
Gman in NC
Just a thought. Make sure the new plugs that you put in are the correct length. A little too long and you will have serious problems.
To C6 help
