C6 aftermarket radio
Old 02-05-2019, 10:42 PM
2005bluesti
2005bluesti's Avatar
Default C6 aftermarket radio
Does anyone know what harness I need to add a aftermarket double din radio. I have a base 2007 with does not have Bose. Homely not even sure I have onstar...
Old 02-06-2019, 12:39 AM
CrystalRedTed
CrystalRedTed's Avatar
PAC RP5-GM11 Wiring Interface. Check out Crutchfield
Old 02-06-2019, 10:18 AM
2005bluesti
I’ve read that before but is there a cheaper harness considering I don’t have steering wheel controls or Bose?
Old 02-06-2019, 01:52 PM
TorchRedFred
TorchRedFred's Avatar
Received 1,636 Likes on 1,121 Posts
I never used this one but another option to the Pac is the Crux SOCGM-17C. Make sure you also pick up a GM antenna adapter if you go with the Crux. The Pac RP5 comes with one in the package. Also if you get your head unit form Crutchfield, they offer the harness and other installation gear in a discounted package. The CRUX package is $25 with a head unit while the PAC is $80 and both packages come with the bezel and the antenna adapter, which is already included with the PAC, is also added to the CRUX package.
Old 02-06-2019, 08:44 PM
CrystalRedTed
Crutchfield does carry a lower cost one that might work.
Old 02-07-2019, 08:42 PM
TorchRedFred
Just for the record, the harness is the same regardless if you have Bose or not. All C6 Corvettes have a factory amp and get connected the same way.
Old 02-08-2019, 11:31 AM
EviLS7
EviLS7's Avatar
I got mine from Best Buy, they usually have one or two in stock. Plus they price match.
Old 02-08-2019, 11:54 AM
hotinaztoo
hotinaztoo's Avatar
Better yet if you buy your head unit from Best Buy, let them install it, and it takes about 35 min and will set it up and explain how it works. love it!
Old 02-08-2019, 11:58 AM
EviLS7
EviLS7's Avatar
I dunno if I would let the install techs from Best Buy in my car. But then again I do all my own work, so it all depends on how comfortable you are with installing things. Radio is easy, since you can wire up the harness in your kitchen and just plug it in after and bolt it all up.
To C6 aftermarket radio
Quick Reply: C6 aftermarket radio
