Urgent: Think my oil is low... But I can't tell
Hey folks,
Thanks for helping me out so quickly, as I am on a short road trip!
I got in my car to leave the beach, and the Check Oil Level message appeared. Since the car should be warm for an accurate reading, I drove the car gently for about 5-7 miles until it was 175 degrees. I then waited 5 minutes for the oil to settle, and I checked it.
Wow, this dipstick is not helpful! However... It seemed that the oil was below the three dots! So, I grabbed the emergency quart from my trunk and added half of it (I only added half because the dipstick was so vague... Didn't want to add too much!).
I then drove another few miles down the road until the oil was north of 200 degrees. I checked the oil again, waiting 10+ minutes this time. The picture is of the reading I got after adding the half quart.
Danger zone?!? Add the rest of the quart? Where did my oil go? I have only had the car for about 3k miles, and the oil life is at 56%.
Repercussions of this incident?
Thank you so much!
Thank you so much!
You're about a quart low, but since you can still see oil on the stick you're not going to break anything. Just add another quart of oil, keep an eye on it while you're on your trip, and when you get back figure out where the oil leak is because you obviously have one. Other than that, just enjoy your trip.
CorvetteBrent (02-26-2019)
even after adding a half quart of oil your dipsticks pics show you still running low oil level. Just ad some oil til it’s on the safe zone.
Ok, so I'll add what I have left in the jug and purchase another quart asap.
Where should the oil level be on the stick relative to the holes?
Received 1,636 Likes
Always remove, clean, then reinsert and remove dipstick to properly check the oil level.
Edit: also wanted to mention that you never want to put too much either. I always try and keep mine in the upper half of the checkered area.
Received 2,093 Likes
How can you say the dipstick is not helpful and vague? How much clearer does it have to be?
The following 2 users liked this post by Vet Interested:
marinablu67 (02-25-2019),
Movie Muscle (02-25-2019)
So to answer your question, my threshold for clear and obvious is much higher than yours.
Thank you so much! So you're saying I'm about 1 quart low based on the picture (after I added the half quart). So I was 1.5 quarts short earlier.
Hope everything is okay with the engine, considering I have been driving around just like normal... (visits to redline when car is warm, etc.) Unknowingly with the engine oil low...
Good thing I had the wherewithal to keep an extra quart handy, though!!
Have you checked under the engine to make sure that is not a severe oil leak? Is the car smoking out the exhaust? Run your finger in the exhaust and see if you have oily residue. The oil went somewhere. Either the oil level was drastically low before you started the trip or you have something wrong.
Exhaust is not smoking. As far as the exhaust tips, my recollection is that they are a bit black inside. Not sure if this is just exhaust residue, or burnt oil. I can grab some pictures a little bit later!
KingCorvette93 (02-24-2019)
Where did the oil register on your dipstick when you bought the car?
Have you changed the oil, or had hit changed since you got the car? If so, where did the oil register on the dipstick when done?
Did they girl/guy that changed your car only put 5 quarts of oil in?
If you lost a quart of oil from a leak since you've owned the car, you would see it on the ground where you park the car.
After purchasing the car, I had a general inspection done at a nice Corvette shop, to keep me abreast of any future maintenance (1.5k - 2k miles ago?). They said the oil level was ok!! (Maybe they didn't really check?)
I park in a parking garage - and not the same spot every day - so it is hard to tell for sure if there is a leak simply by looking at the ground. That being said, I have never seen any obvious drip spots.
Just for reference, the engine sounds good - no ticks, bangs, or clinks that might come from a very low oil situation.
Should be very easy to spot and oil in and around the engine. Not a bad idea to jack up the front, put the car on jack stands and crawl around and see if there is any oily spots.
I have learned that unless I personally have changed the oil, I never trust anyone else especially a dealership to do it right. I would bet that the oil in the car was on the low end of the dipstick from the dealership. If you don't find any leaks, you can bet that the dealership did not check the level and only put in a pre-measured amount.
Example: About 2 years ago, I purchased a used 2008 Audi S4. Very nice car. Has a V8 that takes 9 quarts of oil. I drove 50 miles away from the dealership and I get the low oil level warning. Find an Autozone and end up having to add 3 quarts of oil. Called the dealership (BMW dealership), they actually keep detailed records on how much oil is put into what car when doing an oil change. They have an automated machine and for some reason they only added 6 quarts.
Burning a quart every 1k-1.5k on these LS engines is not uncommon. Especially if you get on it pretty hard at times. Letting the oil level go down a quart or more is often the casue of so many lifter failures as well. Check your level every 1k miles.
Uh...wrong. I've been drag racing my car for the past two seasons and haven't lost a drop of oil. If you're losing oil on a stock motor there's a problem. Oil loss is not something that is common on LS engines.
The following 3 users liked this post by Corvette_Ed:
