Tail lights
Old Mar 31, 2019 | 09:16 AM
tonyb47's Avatar
tonyb47
Default Tail lights
The tail lights on my C6 were painted black by the previous owner. I would like to remove the paint and return them to stock, any suggestions what works best removing the paint. I tried alcohol which worked but very slowly and will be a tedious process
Old Mar 31, 2019 | 09:57 AM
BadAV's Avatar
BadAV
You can probably take it off with a fairly aggressive rubbing compound without messing up the original plastic.
Goof Off would probably work but I would be concerned it might melt the plastic, so I would test it on the back side of the plastic first.
Old Mar 31, 2019 | 10:58 AM
1968swbbigblock's Avatar
1968swbbigblock
Just buy a replacement set
depending on what was used on the old ones you could be in for one hell of a chore even if it can be taken off
Old Mar 31, 2019 | 11:18 AM
madsonp's Avatar
madsonp
You can probably find a good set of used ones pretty cheap in the "Parts for sale" section of this forum. https://www.corvetteforum.com/forums...le-wanted-115/
Old Mar 31, 2019 | 11:28 AM
TorchRedFred's Avatar
TorchRedFred
I have used this stuff. You can get from any Home Depot or Lowes. I've used it on all my cars to remove things that are tough to take off without issue, but never on the taillights so test a small spot first. Have also used it on other projects to remove paint and glue.
Old Mar 31, 2019 | 11:44 AM
tsmart's Avatar
tsmart
I believe Home Depot and Lowes no longer sell Goof Off, apparantly because fumes and druggies huffing it. Too bad because its very useful.
Old Mar 31, 2019 | 01:51 PM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
You can try mineral spirits paint cleaner. Simple and inexpensive.GL
Old Mar 31, 2019 | 06:11 PM
wayback's Avatar
wayback
If it was done properly the lights were sanded before painting. Gonna be a chore to polish them back.
You can use a citrus based paint remover, it should not hurt the plastic. Test first just to be sure. It is sold in plastic bottles.
To Tail lights
