Did My Motor Blow? Hope Not! Video and Sound.
It's funny this would start immediately after a oil change. I checked the oil level 5 times and it is right were it should be. Even thou the dipstick is correct how do I know the oil is actually circulating .Could I have done something while changing the oil to cause this?
Steel City (04-16-2019)
Received 3,093 Likes
2021 C6 of the Year Finalist - Modified
So, nothing I told you in my post seems to interest you ?
ok .... good luck
ok .... good luck
vett_guy (04-08-2019)
Supporting Vendor
2013 Grand Sport, bought new and babied for 26k miles. I changed the oil yesterday (dry sump) like I always do every year at this time. I only put 1000 miles since the last one. Always Mobil1. That's a little background. I have been using the car these two days and noticed when I was parking it today a ticking or whatever sound. I opened the hood to listen to this. At first I thought it might be the compressor but on or of makes no difference (doesn't mean it can't be the clutch) However the sound seems to be coming from all over consistently, each side of the motor, each wheel well and underneath (from bending down and listening). Tell me I'm not screwed, but if it is I have to accept it.
https://www.youtube.com/watch?v=8Xoud0W4mMs
It sounds exactly like when I had a lifter problem on my'05. Never had any codes.
That don't sound like anything internal inside the engine.
Get under the car and look at the harmonic balancer when it's not running ... Is the front of the balancer chewed up from rubbing up against the steering rack (that sets right in front of it) ?
Does the rear of the balancer look like it's been rubbing up against the timing chain cover ?
_________________________________
If that's ok ... remove the serpentine belt (the long one .. not the short one that turns the AC compressor)
Start it up and let it idle for about 15 seconds without the belt (won't hurt anything) .... Does that noise go away then ?
If the noise then goes away, you have a problem with one of these:
1. Water pump
2. Alternator
3. Power Steering Pump
4. Belt Tensioner
5. One of the 2 Idler Pulleys
1. Water pump
2. Alternator
4. Belt Tensioner
There is not that much I can do here as I am knowledge limited. I just went and started it again and it seems louder and it is definitely rpm dependent. Goes up and down with throttle. I looked in the oil cap on the head right after I shut it and it doesn't seem really wet in there. Shouldn't that be coated in oil? Here's a pic 10 seconds after shutting it off.
https://www.youtube.com/watch?v=Te1P...ature=youtu.be
Received 1,137 Likes
Here ya go, hope this helps, on the good side!
You have to rule out one thing at a time. I would do what Turbo suggested and remove the belt. That would tell you a lot. Do you have any mechanically-inclined buddies that could help you?
#33
Supporting Vendor
The lifters in our cars are hydraulic meaning they're fluid filled with oil. When you drain the oil the lifters tend to bleed down which is why a motor can sometimes be a little noisy on initial startup after an oil change since it takes a few seconds for them to fill up again.
Even though the oil change itself didn't cause the issue, my guess is that it pushed a borderline bad lifter over the edge because after it bled down when you drained the oil, some internal fault prevented it from filling back up properly so basically instead of riding on a cushion of oil you've got metal to metal contact inside.
The good news (and this is speaking from experience, not wild speculation) the motor isn't necessarily shot. At best you're looking at having to replace the lifters, at worst you may also have to replace the cam too if the lobes got chewed up.
Landru (04-09-2019)
#35
That definitely sounds like a bad lifter and it absolutely could have started as a result of the oil change.
#36
Of course I am clutching at straws here but wouldn't a bad lifter sound come from the area of the bad lifter? This sound although it does sound like a lifter seems to be coming from all over and not one distinct area.
#37
#38
Of course anything can happen, but just playing the odds: The chances of a bad lifter on a "bulletproof" LS, with 26k miles, "babied since new," are really slim.
But we shall see, in the fullness of time . . .
#39
Oh Boy ...
Bottom line ... When you find out what was making that noise from your engine, you be damned sure to let us know what the problem was .... Ok
Steel City (04-08-2019)
