Did My Motor Blow? Hope Not! Video and Sound.
#41
That don't sound like anything internal inside the engine.
Get under the car and look at the harmonic balancer when it's not running ... Is the front of the balancer chewed up from rubbing up against the steering rack (that sets right in front of it) ?
Does the rear of the balancer look like it's been rubbing up against the timing chain cover ?
_________________________________
If that's ok ... remove the serpentine belt (the long one .. not the short one that turns the AC compressor)
Start it up and let it idle for about 15 seconds without the belt (won't hurt anything) .... Does that noise go away then ?
If the noise then goes away, you have a problem with one of these:
1. Water pump
2. Alternator
3. Power Steering Pump
4. Belt Tensioner
5. One of the 2 Idler Pulleys
1. Water pump
2. Alternator
4. Belt Tensioner
#42
Supporting Vendor
The lifters are pretty much located in the center of the engine and once again from experience, I can tell you that it's one of those things where if several people all listened to it you'd get multiple answers as to where the noise was coming from.
#43
Supporting Vendor
That makes perfect sense however, I have used the car for a day and it was perfectly quiet. When you shut the car off and don't use it for hours isn't that the same thing as when you change the oil? Meaning all the oil is in the bottom anyway and it bleeds down every time you let it sit? Or in other words this would have happened anyway without the oil change because every time you let the car sit it bleeds down anyway. Just trying to understand this. Ball park figure of replacing lifters?
I can change them all in under five hours and the reason it takes that long is because the intake manifold as well as both heads and a few other parts all need to be removed as well.
If you start shopping around for estimates I'd recommend getting several because if a less than reputable shop catches even the slightest whiff you're not that familiar with the job you could get taken advantage of.
#44
I have noticed you never have anything nice to say especially in threads I'M IN and I don't even know or interact with you. I can do a lot of simple things on cars (brakes, OIL CHANGES, plugs wires, fuel pumps etc...) but every time I do one of those belts I never get in on right, off is easy.
Steel City (04-16-2019)
#45
If you can do all of these things, you most certainly can do a belt. For reinstall I usually start with a pulley that once the belt is hung from it will support itself and I just work my way around with the last one going on the tensioner. I’m no mechanic but that’s what has worked for me.
#47
Received 1,136 Likes
OP: All things considered, were it me I would take the belt off as Turbo suggested. If it still makes the noise then all the driven items on the front of the engine are ruled out. If the noise is gone, then the problem is one of those items. It's a simple, quick test.
Worry about getting the belt back on later.
#48
#50
C5 of Year Finalist (stock) 2019
St. Jude Donor '19-'20
I thought you committed Forum suicide
https://www.corvetteforum.com/forums...is-odd-10.html
I'm with turbo on this one
Steel City (04-08-2019)
#51
#52
Supporting Vendor
#53
#54
Don't pay him no mind.
Nothing there has anything to do with anything here, can we stay on topic here, I have a potentially serious problem
#55
#59
Received 3,633 Likes
2016 C6 of Year Finalist
#60
Supporting Vendor
