Halo replacement 2005
Old 07-06-2019, 11:39 AM
EuroRod
EuroRod's Avatar
Default Halo replacement 2005
Anyone replaced the halo on a 2005?
If so, what did you do with the “radio wart” ?
thanks
Old 07-07-2019, 12:57 AM
Riveroger
Riveroger's Avatar
I changed mine to a black one without the Xm antenna. I hated that wort. Its not hard to do.
Old 07-07-2019, 11:07 AM
Dutch08
Dutch08's Avatar
I removed the wort, wrapped the halo to black to see if I would like the look. I liked it so much that I still need to fix the hole permanently and paint the halo 2 years later.
Old 07-07-2019, 12:15 PM
EuroRod
EuroRod's Avatar
OK, but what did you guys do with the wart? Disconnect the wires and tape them off, or ???
If yes, I assume will ruin the radio reception, OnStar and anything needing an antenna?
thanks
Old 07-07-2019, 01:39 PM
saplumr
Support Corvetteforum!
saplumr's Avatar
Received 1,251 Likes on 895 Posts
thanks
Can’t help on the halo business but that is strictly a xm antennae
Old 07-07-2019, 01:42 PM
EVRose
EVRose's Avatar
thanks
If you want to keep XM/Sirius radio just get an aftermarket antenna and put it anywhere inside the car. It will plug into the XM module just like the factory antenna does.
Old 07-07-2019, 03:24 PM
EuroRod
EuroRod's Avatar
Old 07-07-2019, 04:12 PM
Riveroger
Riveroger's Avatar
thanks
I have a kenwood head unit and have no need for Xm or onstar. Got the black halo on eBay for $90.00 delivered. I have a black transparent top and window tint so the look works for me
Old 07-08-2019, 10:48 AM
Dutch08
Dutch08's Avatar
thanks
Since I plan to someday remove and paint the halo, I just snipped the wire and nothing more. In my 05 only the XM radio band was affected and everything else still works fine. If I want XM radio in the future I'll get a new antenna and plug it into the XM receiver which (I understand) is located behind the side panel behind the driver.
To Halo replacement 2005
Quick Reply: Halo replacement 2005
