Navigation disk question..
Old Oct 24, 2019 | 05:47 PM
NCC-1701's Avatar
NCC-1701
Default Navigation disk question..
Is version 10 the last map updated disk for a 2009 Z06, thanks.
Old Oct 24, 2019 | 06:02 PM
captain vette's Avatar
captain vette
yes it is.
Old Oct 24, 2019 | 06:12 PM
NCC-1701's Avatar
NCC-1701
Originally Posted by captain vette
yes it is.
Thank You
Old Oct 25, 2019 | 10:00 AM
dr_gallup's Avatar
dr_gallup
It's the last disk ever for any of these DVD based systems.
Old Oct 25, 2019 | 10:28 AM
Oh Boy's Avatar
Oh Boy
Here ya go, works perfect.
Old Oct 29, 2019 | 03:33 PM
tcs89coupe's Avatar
tcs89coupe
I ordered this one about two weeks ago (Version 10). The one that I received was Version 9.0c (same part number).
Old Oct 29, 2019 | 04:26 PM
Iceaxe's Avatar
Iceaxe
If you bought it on Ebay dispute the item as "not as advertised" and they will refund your money. It's a simple process and takes about 3 minutes. You might need to include a picture of the disc so be prepared.
Old Mar 4, 2020 | 04:57 PM
klangstone's Avatar
klangstone
Question regarding this v.10 DVD (shown above). I bought a used 2005 and the nav DVD is missing. I purchased this cheap ebay DVD but it has not arrived yet.
Can I simply plug in this updated map disc and I will have functional navigation without having the original OEM DVD in my possession?
Old Mar 5, 2020 | 02:40 PM
dr_gallup's Avatar
dr_gallup
I'm sure you won't need the original DVD. I'm not 100% sure a 2005 can read the newer dual layer DVD but I think it can.
Old Mar 5, 2020 | 05:03 PM
4SUMERZ's Avatar
4SUMERZ
Yes it will work on 2005-2013 Nav unit without issues.
Old Mar 5, 2020 | 05:37 PM
klangstone's Avatar
klangstone
Thank you both very much! (Unrelated) Now I just gotta figure out why my CD player says there is no disc in the player after turning the car off and trying to play the audio CD next time I get in the car. Plays the CD only the first time you insert it, after that it doesn't see the disc if the stereo is powered off and back on again. :-(
Old Mar 5, 2020 | 06:00 PM
4SUMERZ's Avatar
4SUMERZ
The CD is finicky at best. When the CD gets dust inside, it starts to do what you are experiencing. Most times, get a can of compressed air from an electronic store, and blow air into the CD slot. Hopefully it will clear any dust from the laser lens or the prism under the lens. A CD cleaner disc sometimes works as well. I've used both before to clear the issue.
Worse case is the the cover of the Nav unit can be removed to get access to the top of the CD player. The CD table can be moved manually to get access to the lens to manually clean it with alcohol on a Q-Tip.
Old Mar 5, 2020 | 06:20 PM
klangstone's Avatar
klangstone
Thanks again 4sumerz!
I tried the "blow air" bit but wasn't sure exactly where in there to blow, so I tried to blow it all across the inside of the opening. It seems to help but not completely fix it. I did purchase a CD cleaner disc and will try that when it arrives.
Old Mar 6, 2020 | 05:24 AM
ESAFO's Avatar
ESAFO
Originally Posted by Oh Boy
Here ya go, works perfect.=13px
Have been thinking about ordering 1 of these myself, question is that much better than stock disc?
Have read some say yes & others say no its a waste of $?
What are the differences & if possible would members that have updated disc take screen shot to show the graphics.
Old Mar 6, 2020 | 08:42 AM
BadAV's Avatar
BadAV
It's less good than Google Maps or Waze, but it provides updated maps. And it's available even if you don't have phone service and didn't download off-line maps to your phone before your trip. It's worth the few dollars to update it.
Old Mar 6, 2020 | 09:28 AM
4SUMERZ's Avatar
4SUMERZ
There is no difference in the graphics from from the original Nav DVD. The newer roads have been added, and more POI's were added from the previous versions.
Old Mar 6, 2020 | 09:30 AM
ESAFO's Avatar
ESAFO
Thanks for the info
Old Mar 9, 2020 | 10:45 AM
klangstone's Avatar
klangstone
The cheapo nav disc seems to be working. It took a minute to load but once initialized it is showing my location map. I haven't driven the car with it on yet but so far so good!
Old Mar 12, 2020 | 10:32 AM
klangstone's Avatar
klangstone
Drove the car with the nav turned on and it shows the map while driving. Haven't done anything else with it like putting in a destination and using it for directions, but still so far so good on it working legitimately.
To Navigation disk question..
