replacing LS3 engine air filter
Old Dec 2, 2019 | 07:12 PM
joec's Avatar
joec
Default replacing LS3 engine air filter
Have looked around and have heard about various methods to replace.... Any inputs would be appreciated.. probably just going to go with stock filter...
thanks,
/jc
Old Dec 2, 2019 | 07:22 PM
Richard G.'s Avatar
Richard G.
I put K&N filter in mine. I have used them for a number of years
on a variety of vehicles. I am pleased on their performance.
Some people will say they do not like them be cause they have
contamination on throttle body and they let dirt in.
I have not had any problems.
Old Dec 3, 2019 | 07:23 AM
Solaris's Avatar
Solaris
If you want something between a paper element and an oiled one, the aFe Pro Dry S is a good option. It's washable and doesn't need oil. You get less flow than an oiled filter, but more filtration, and still more flow than paper. I use these filters on 2 of my other cars and intend to use one on my Corvette when the time comes.
Old Dec 3, 2019 | 07:54 AM
Corvette_Ed's Avatar
Corvette_Ed
You could try my method, but I don't think you'd like it much. I ran over a mini boulder (about 10" round) at 55 mph, which destroyed the entire front end of the car, the engine cradle, most of the exhaust, the passenger side floor pan, and the lower passenger side rocker arms on front and rear. Everything in front of the throttle body was replaced, which included the air filter.
Old Dec 4, 2019 | 08:32 PM
joec's Avatar
joec
Yikes.. No I just want an easy to remove and replace procedure.. ;-)
Old Dec 4, 2019 | 09:09 PM
Corvette_Ed
Yeah, lol, I didn't think anyone would want try try my method.
Old Dec 4, 2019 | 10:41 PM
FatsWaller's Avatar
FatsWaller
thanks,
/jc
Here's what I use in my LS3 - ACDelco A3107C Professional Air Filter
Haven't heard of various methods to replace, but it's very straight forward. Took me about 20 minutes, give or take.
K&N might have the potential to flow better, but they will pass more dirt. I posted a comparison of various filters some time ago, and K&N doesn't score very well for dirt. AC Delco scored the best, and I doubt that they have any noticeable restriction for a stock LS3..
Old Dec 5, 2019 | 01:13 AM
Cherokee Nation's Avatar
Cherokee Nation
A little Dirt won't hurt your engine...Maybe after 200,000 miles.
Old Dec 5, 2019 | 06:02 AM
449er's Avatar
449er
CF Community Team
thanks,
/jc
The GM stock paper filter is a quality product, If you have a stock engine, stick with that
Old Dec 6, 2019 | 12:29 PM
KyJim's Avatar
KyJim
here is an article with photos on replacing the air filter. I have just stayed with the factory filter and no issues.
File Type: docx
Old Dec 6, 2019 | 03:34 PM
taguid's Avatar
taguid
I put in an Attack Blue air filter. Seem to work well since I have been using for about a year.
Old Dec 6, 2019 | 06:21 PM
Zapp Brannigan's Avatar
Zapp Brannigan
I used to run oiled filters in my old Silverado until I had to replace my first MAF sensor due to oil damaging the wire. It was beyond being able to be cleaned. Good paper filters are fine unless they are neglected for mostly stock/mild setups.
To replacing LS3 engine air filter
