No antiseize on plug threads
Old Dec 14, 2019 | 10:01 AM
Unreal's Avatar
Unreal
Originally Posted by Wayne88
This sounds right to me.
But the plugs we are talking about are not steel, they have an trivalent coating built into the plugs. Antisieze in this case only causes issues, especially if too much is used, you can actually cause spark issues since they ground through the plug.
https://www.ngkplugpro.ca/content/co...SparkPlugs.pdf
Old Dec 14, 2019 | 10:04 AM
Norskie's Avatar
Norskie
Well, I am glad this issue has been settled! The one point I take away from this discussion is, don’t take advise from the engineers that designed and tested their plugs.
Old Dec 14, 2019 | 10:37 AM
windyC6's Avatar
windyC6
LOLOL....Well said and . I thought the "wax - on - wax off" and the "change your brake fluid every 6 months" experts were confused. A "release agent" on your plugs threads.....that sounds like a Tide laundry detergent commercial...LOL. ....and "never change your plugs while the engines hot".....chit....I found out years ago that if you have enough room to do it without burning your hands then the plugs come out a heck of a lot easier and never had an issue doing it that way. And no anti seize.......yes to anti seize......over torque......under torque......In the immortal words of that great coach Vinny Lombardi while standing on the sidelines....."What the hells going on out there??"..........: woohoo:
Old Dec 14, 2019 | 11:27 AM
captain vette's Avatar
captain vette
torque to spec and no anti seize.
Old Dec 14, 2019 | 12:03 PM
TonyFaub's Avatar
TonyFaub
as many times as i have had to remove both oem and aftermarket plugs on all types of cars and them being stuck or tight AF, i will continue to do it my way, tiny bit of antiseize and snug lol
I've never had a misfire due to antiseize, and only one untimely failed plug in 30 years, during racing, at full throttle and stuff
Old Dec 14, 2019 | 04:42 PM
Dutch08's Avatar
Dutch08
Originally Posted by FAUEE
.......I've seen a lot of these pre coated spark plugs, I still add antiseize. The real trick is not to overtighten your plugs! Finger tight, then a quarter turn. If it dries out and gets a little stiffer, no big deal because you didnt go nuts with the torque from the get go. The coated ones are likely a godsend for a monkey with an impact gun, but irrelevant if you do things properly.
After reading all the threads to date, I think ..
Antiseize - you don't have to use it, but it can't hurt and might help.
"Finger tight, then a quarter turn" - I don't know if this is the correct spec, but an initial torque and then a tighten angle should give you the correct "tightness" regardless of whether the threads are only clean or lubricated for the spark plug you are using.
Old Dec 14, 2019 | 05:02 PM
WW7's Avatar
WW7
You can use all the information above when you get around 80,000 to 100,000 miles on the plugs in the car... There is no way that you need plugs at 47,500 miles.. Most of us that pull the plugs at around 100,000 miles say they still look good... Why waste your money , save your money and buy a case of Corona....WW
Old Dec 14, 2019 | 06:47 PM
Unreal's Avatar
Unreal
It can cause overtorquing, and depending on the antisieze used, less spark performance or misfires because the plug can't properly ground through the excessive antisieze. The opposite is true, following the manufactures suggestion and letting the built in coating do its work can't hurt, antisieze can only hurt.
Old Dec 14, 2019 | 09:33 PM
Patsgarage's Avatar
Patsgarage
Never seize does make it much easier to remove a plug if this happens...............
Old Dec 14, 2019 | 11:00 PM
Josephu's Avatar
Josephu
If you are a real car guy......and not someone who goes to stealers.....someone who throws their cars up on jack stands in 15 minutes or less......someone who is not afraid to tackle mechanical problems........Someone who was born before 1950......Then you know in your mind and in your heart what you can do and what you cant do on a car. No forum is going to tell you otherwise. .....Have a nice Christmas everyone.....
Old Dec 14, 2019 | 11:22 PM
TonyFaub's Avatar
TonyFaub
real car guys have lifts
Old Dec 15, 2019 | 09:43 AM
Josephu's Avatar
Josephu
Lift guys are rich.....The rest of us are just junkyard dogs......
Old Dec 15, 2019 | 10:00 AM
  #33
BadAV's Avatar
BadAV
If you are the type of person who leaves plugs in for 100k miles you might be in for a nasty surprise when you try to take them out. I prefer to add a light coating of antiseize as a little added peace of mind.
I generally change plugs at 50k to keep things running properly without any concerns. Again, cheap insurance for peace of mind when on the road. Heard reports that F-150 3.5 ecoboost was hard on plugs; I recently noticed a little stumbling and longer crank at cold start so I pulled mine at 30k miles. The reports were correct, but you had to look closely to see it. The center electrode firing into the ground strap had worn a quite deep crater, greatly increasing the effective plug gap. New plugs resolved the cold start stumbling.
Old Dec 15, 2019 | 11:04 AM
  #34
Dutch08's Avatar
Dutch08
Good point!!! Antisieze is not a conductor. ( The nerd in me just checked with my ohm meter.) But the correct torque angle is designed to give you the correct torque with or without lubrication as I understand it, since it is based on bolt stretch not resistance to torque.
Old Dec 15, 2019 | 01:26 PM
  #35
old motorhead's Avatar
old motorhead
I won't install a spark plug without anti-seize. Been doing that for 50 years. Just a little dab will do ya' on LS plugs. On bigger industrial engines, I coat the plugs liberally.
I bought a used GMC 4.8L pickup with 120K miles on it. About half of the plugs came out really difficult. Probably original plugs. The new ones got a little dab of anti-seize.
If you're not a mullet, there's no down side to using it. Yes, it's slightly easier to over torque them. The next time I use a torque wrench installing spark plugs will be the first time. And yes, you can glob it on there and possibly foul plugs. Again, if you're not a mullet.....
Old Dec 15, 2019 | 01:50 PM
  #36
FAUEE's Avatar
FAUEE
The threads wont do the grounding as much as the giant crush washer around the base of it...
Old Dec 15, 2019 | 02:00 PM
  #37
BadAV's Avatar
BadAV
Do our car plugs really have crush washers? I don't remember a car/truck I owned that had them in multiple tens of years, if ever. They all had tapered seats. My 1966 Farmall 706, however, had them.
To No antiseize on plug threads
Old Dec 15, 2019 | 03:43 PM
  #38
Unreal's Avatar
Unreal
True, but assuming you didn't put so much damn antisieze on it also covers that.
As for washers, if it is factory yes. Heads on my car don't use a washer plug, so in my case with Brodix heads, no they are not washer plugs.
Old Dec 16, 2019 | 12:47 PM
  #39
HOXXOH's Avatar
HOXXOH
Crush washers are not used on aluminum heads, due to the torque required to crush them enough to seal is greater than the capacity of the internal threads in the head to resist stripping.
This thread has lots of good and lots of bad info. The problem is telling the difference between the two. If you have doubts, follow the manufacturer's advice.
Old Dec 16, 2019 | 11:06 PM
  #40
PCMusicGuy's Avatar
PCMusicGuy
I had no issues taking factory plugs off my daily driver @ 75k miles. I used factory plugs again without anything extra. I will see how they look @ 160k miles.
