Low Beam Issues
Old Dec 16, 2019 | 07:13 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default Low Beam Issues
I've read a few threads about people having issues with the low beam lights not working after the car is driven and heated up. All I read says that I need to have the recall done to my 2008. The thing I don't understand is when the headlights go out and I turn the car off, if I use the key fob to lock and unlock the car, when I unlock, the low beams come on for a brief amount of time. Is power to the low beams routed via a different path than when i just try to turn them on?
Old Dec 16, 2019 | 09:15 PM
ls1121's Avatar
ls1121
I cannot find anything on the headlight for my 2008? Does anyone have info on how to get GM to do this repair?
Old Dec 16, 2019 | 09:59 PM
rvsullivan's Avatar
rvsullivan
St. Jude Donor '20-'21,'24-'25
I don't think you can it for free after 9/10 years. But they will gladly do it if you pay!
Old Dec 16, 2019 | 11:20 PM
torquetube's Avatar
torquetube
I think you're seeing the DRLs flash when you press the lock button, not the headlights.
It's a safety recall that's good forever. If yours hasn't been done, you're eligible for a free repair. Go here and type in your VIN:
https://my.gm.com/recalls
Old Dec 17, 2019 | 10:05 AM
4SUMERZ's Avatar
4SUMERZ
Because it is a safety recall, there is no expiry date. I have a 2006 that the recall has not been done, but if it happens, I will do the repair myself. It is fairly straight forward, basically bypassing the broken ground wire with another wire.
Good Luck
Old Dec 17, 2019 | 10:16 AM
Armyboy79's Avatar
Armyboy79
Default Low Beams
I just got the headlight recall done on my 05, free of charge from the dealer.
Old Dec 17, 2019 | 10:22 AM
Corvette_Ed's Avatar
Corvette_Ed
Just contact your local dealer and make an appointment. They'll fix it for free.
Old Dec 17, 2019 | 10:23 AM
Travlee's Avatar
Travlee
mine had the jumper, and a new fuse box. occasionally when it hit a bump both my lights would flash off for a brief second. never did find the cause before i parted ways with it
Old Dec 17, 2019 | 11:18 AM
4SUMERZ's Avatar
4SUMERZ
Here is the Headlight recall bulletin from GM - This one is for 2005-2007 C6 Corvettes. According to GM, C6 models from 2008-2013 will be covered under a Customer Satisfaction Program. All repairs will be at no cost to customers.
This link shows how to DIY the fix
https://www.corvetteforum.com/forums...dlights-6.html
Old Dec 17, 2019 | 07:22 PM
ls1121's Avatar
ls1121
OK this shows my status as incomplete. Thank you.
Old Dec 17, 2019 | 07:35 PM
ls1121's Avatar
ls1121
OK You guys are Great! I've got everything printed out and will look for a dealer that has done this in my area.
Thanx again.
Old Dec 17, 2019 | 08:00 PM
ls1121's Avatar
ls1121
[QUOTE=torquetube;1600658782]I think you're seeing the DRLs flash when you press the lock button, not the headlights.
No it is the headlights, i'm standing in front of the car looking at them. They stay on for 10-15 seconds, kinda weird.
Old Dec 17, 2019 | 08:21 PM
03BlkZ's Avatar
03BlkZ
[QUOTE=ls1121;1600663436]
On my car when I hit the lock button its the day time run lights that flash and when I hit the in lock the high beams come on for an out 10 seconds. This is normal and the lights come on to give you some light as you approach your car.
Old Dec 18, 2019 | 02:15 AM
torquetube's Avatar
torquetube
What you're describing sounds like the Approach Lights feature, except that should activate the DRLs and fog lights, not the low beams.
There's also an option for the headlights to stay on for a bit after you exit the car at night.
Old Dec 18, 2019 | 04:15 AM
wayback's Avatar
wayback
My 07 does the same. Have checked that all exterior lights are working by unlocking with the fob many times.
Not sure why they would come on if they were not working just before unless the ground wire cools down quickly enough to reestablish connection.
Old Dec 18, 2019 | 05:00 PM
ls1121's Avatar
ls1121
OK, I stopped by Ben Mynatt Chevy today and showed them the paper. He typed in my Vin and gave me an appointment for Monday @ 8am, there will be no charge. He said that they might have to order parts, if there was an issue with parts he would call me tomorrow. Thanx guys for the help.
Old Dec 18, 2019 | 07:15 PM
Corvette_Ed
Glad you got it sorted out.
To Low Beam Issues
Old Dec 23, 2019 | 04:39 PM
ls1121's Avatar
ls1121
Got the car back and I now have headlights. Can't really see what was done? Where did they do the repairs and can I see it?
Old Dec 23, 2019 | 04:52 PM
4SUMERZ's Avatar
4SUMERZ
The repair is done inside the engine fuse panel. They add a jumper that bypasses the broken ground wire. I believe it shows it in the PDF that I attached in post # 9.
Happy to hear that you were succesful in getting the repair completed.
Old Dec 23, 2019 | 09:17 PM
ls1121's Avatar
ls1121
Thank You!
I can tell you this is one hellava knowledge base.
