Radiator support..
Old Jan 16, 2020 | 09:52 PM
Vette2lo's Avatar
Vette2lo
Default Radiator support..
My rad support is cracked/broken from a few places on my 08 z06 and looking to replace it.
Cranescorvette sells but I have no luck trying to get a hold of them, no contact number on their site.
Any other recommendations? Better quality than OEM?
Thanks!
Old Jan 16, 2020 | 10:25 PM
FatsWaller's Avatar
FatsWaller
GMpartsdirect has them https://www.gmpartsdirect.com/auto-p...r-support-scat
Ecklers https://www.ecklers.com/catalogsearc...?q=Rad+support
Cultrag https://www.cultragfactoryparts.com/...plate-20939829
Don't hit parking curbs. Probably most common cause of breakage
Old Jan 17, 2020 | 12:28 AM
vetteJPJ's Avatar
vetteJPJ
I just bought one from cranecorvettes off ebay for 279.00. Excellent fit and a bit beefier than OEM.
https://www.ebay.com/itm/2005-2013-C...53.m2749.l2649
Old Jan 17, 2020 | 12:54 AM
owc6's Avatar
owc6
Originally Posted by FatsWaller
I know this does not help the OP, but it is most likely the only cause of breakage. Might help someone else perusing the forum: Back in only.
Old Jan 17, 2020 | 01:03 AM
salt6's Avatar
salt6
Found the contact page.
http://cranescorvettesupply.com/about-us/
Old Jan 17, 2020 | 01:04 AM
vetteJPJ's Avatar
vetteJPJ
First time I hit a pothole that was full of water. Couldn't tell it from the rest of the road. Second time I crossed an unknown intersection and the far side was a huge dip. Both times I needed new supports. second time it bent my radiator and broke upper bracket too. Never had a problem parking the car, but I did just install a front camera for this eventuality.
Old Jan 17, 2020 | 01:42 AM
owc6's Avatar
owc6
Ok, pulling in front forward is only 98 or 99% of the problem. (just an observation from previous threads on the subject).
Sorry you had that happen. Hidden surprises: I had that happen (hidden pothole), and it broke my HUD.
Old Jan 17, 2020 | 01:58 AM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
You might want to install a pair of our Fangs on your new support to help prevent breakage again.
Here is the info and how they work.
www.saccitycorvette.com/C6-Fangs.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jan 17, 2020 | 09:57 AM
vetteJPJ's Avatar
vetteJPJ
I did install the fangs.
Old Jan 17, 2020 | 11:18 AM
Corvette_Ed's Avatar
Corvette_Ed
Mini boulders sitting in the middle of the freeway don't help either.
Old Jan 17, 2020 | 02:08 PM
FatsWaller's Avatar
FatsWaller
or do raccoons. https://www.corvetteforum.com/forums...d-i-break.html
Old Jan 17, 2020 | 04:50 PM
Vette2lo's Avatar
Vette2lo
Originally Posted by salt6
thanks! I just spoke to them.
Old Jan 17, 2020 | 06:40 PM
Kimball's Avatar
Kimball
Thanks!
I removed mine. Didn’t take long, and had it welded for about £40 by an aluminium welding specialist. Had 3 breaks and a missing mounting tab, they also made one of them up and welded in place.
Old Jan 18, 2020 | 01:58 AM
SacCityCorvette
Supporting Vendor
Hi,
What did you hit that caused it to break?
Christian
Old Jan 18, 2020 | 08:52 AM
Pozzo6819's Avatar
Pozzo6819
I just bought mine from Eckler's for $350 on sale. The welds seem sturdier than those on the OEM piece. It comes unpainted so I spray painted it black.
I don't believe that hitting parking curbs is the most common cause of breakage. Here in the northeast I believe potholes cause the most breakages.
Old Jan 18, 2020 | 11:47 AM
vetteJPJ's Avatar
vetteJPJ
Originally Posted by SacCityCorvette
Hi,
Christian
See post #6
Old Jan 18, 2020 | 01:24 PM
Pozzo6819's Avatar
Pozzo6819
I live on Long Island and we have some enormous potholes, I think the full weight of the car came down on the skid plate and caused it to break. On the driver's side, both of the skid plate attaching bolts broke off and the curved part of the piece was also cracked. It must have taken quite an impact to cause that much damage. The upper radiator support, which is plastic, also broke.
I don't think it is possible to break it on concrete parking curbs because the lower part of the front fascia would hit first and scrape up the paint. Even if you did manage to hit the skid plate while parking, you would only be going a couple of miles per hour and the impact would not be intense enough to break the plate.
To Radiator support..
Old Jan 18, 2020 | 04:43 PM
Pozzo6819's Avatar
Pozzo6819
Which threads suggest that most broken skid plates are caused by parking curbs. I don't believe it is possible to break them this way.
When pulling in forward, the lower part of the front fascia would hit the top of the concrete curbs and scratch up the paint. Even if you went far enough to hit the skid plate, you would be going too slowly to break the skid plate.
Old Jan 18, 2020 | 10:43 PM
SacCityCorvette
Supporting Vendor
See post #6
Sorry missed that post. Ya, those are some hard hits. Not much you can do to protect when the support gets that kind of impact.
A local Corvette friend here in Sacramento hit a pot hole that was full of water and it broke his rim and tore up part of his wide body kit.
He was pissed and called the county and they paid for a shop to fix it.
Christian
Old Jan 18, 2020 | 10:48 PM
owc6's Avatar
owc6
Yep, the "fang" "may" help cosmetic scrapes, but nothing is going to help an actual whack.
