Harmonic Balancer
Old Nov 6, 2020 | 11:52 AM
h8snow's Avatar
h8snow
Originally Posted by GigG
So you would replace a known defective part with the same defective part?
You tell me.
Old Nov 6, 2020 | 01:27 PM
Jaime-Corvette's Avatar
Jaime-Corvette
Originally Posted by h8snow
You tell me.
yes... you absolutely would replace a defective part with a known defective part. That balancer fails on you once on the road and your whole motor is F'd.
Old Nov 6, 2020 | 01:44 PM
h8snow's Avatar
h8snow
Have you replaced yours? If you have how did you process loosing the factory balance?
Old Nov 6, 2020 | 02:11 PM
D-Dub2013's Avatar
D-Dub2013
The Innovators West balancers are really nice. Not cheap, but worth it for the quality.
Old Nov 6, 2020 | 03:03 PM
Jaime-Corvette
I did replace it and I have a thread of it. For a long time my alternator was not charging the battery. I would get new alternatos but the oem one was always fine.. the new ones acted the same.. my car wouldn't turn on when trying to go home from work.. i dealt with this for a long time couldn't figure it out.
​​​then I discovered that balancers have an effect on voltage. Dampeners charge lss and vise versa. I knew that my balancer was probably the culprit because it had some wobble therefor this wobble was affecting my charging system. it was not consistent. I assumed this.
I replaced my slightly wobbly balancer to a powerbond and problem solved.
Thats how.
Old Nov 6, 2020 | 03:17 PM
Red Greene's Avatar
Red Greene
Ooooo😮
Old Nov 6, 2020 | 03:45 PM
Walt White Coupe's Avatar
Walt White Coupe
That's ridiculous, other than being part of the system that turns the alternator they will have no effect on the electrical system.
Old Nov 6, 2020 | 04:10 PM
Jaime-Corvette
it is true. do some research
Old Nov 6, 2020 | 04:50 PM
Walt White Coupe
Why don't you tell us all what possible way a wobbling balancer could affect the voltage. And then you can tell us how washing your car makes it run better.
Old Nov 6, 2020 | 04:58 PM
Jaime-Corvette
Why don't you explain to me how changing my balancer fixed my charging system problems.
look man, I assumed that's what it was because even ati super dampers cause low voltage problems. I assumed a wobbly balancer may affect voltage somehow so I changed it, and tada it worked.
literally go do some research on balancers and voltage
Old Nov 6, 2020 | 05:13 PM
MysteryMob's Avatar
MysteryMob
You made the claim, the burden of proof rests on you.
Old Nov 6, 2020 | 08:05 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
I had mine replaced recently under warranty. If it goes again I will replace with an aftermarket piece.
Old Nov 6, 2020 | 08:25 PM
  #33
Walt White Coupe
Just curious, at how many miles? Was it chirping?
Old Nov 6, 2020 | 08:31 PM
  #34
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Balancer
We thought you didn’t care.
Old Nov 6, 2020 | 09:51 PM
  #35
Petr702's Avatar
Petr702
I changed mine back in 2015 do to it was chirping and had just purchased an sc kit so I figured might as well get an ATI and have it done with the sc install. 5 years later and no issue with the ATI . Well worth it even though at first it hurt coughing up the $$$ lol
Old Nov 6, 2020 | 09:54 PM
  #36
Jaime-Corvette
I'm not trying to prove anything though.
But do you really want me to go on here and do look at these claims for you? I just went with what others said and heck it worked.
Old Nov 7, 2020 | 07:30 AM
  #37
Sabre34's Avatar
Sabre34
Moderator
31000 miles. It had been chirping.
To Harmonic Balancer
Old Nov 7, 2020 | 08:14 AM
  #38
Walt White Coupe
Well, that's a great explanation of how a wobbling balancer could cause an electrical problem. So basically you don't know how it could be related. And that makes sense because there is no relationship unless the balancer fell off.
Old Nov 7, 2020 | 12:04 PM
  #39
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
I'd like to know how a wobbling HB would cause charging issues?
Yes, my HB was replaced with ATI and alternator with Mechman but these issues were not related.
Old Nov 7, 2020 | 01:32 PM
  #40
h8snow's Avatar
h8snow
How many miles have you driven with your ATI damper? Is your car a manual or auto? I watch mine closely at 30000 miles all good so far. Just freaked about the balance procedure that GM used. Think it is more of an issue with the manual than auto.
