Tpms?
Old Feb 20, 2021 | 03:14 PM
USA1LBvert's Avatar
USA1LBvert
Default Tpms?
Ok so I bought a new set of wheels and now ordering some new rubber. Should I get new tpms sensors? Car is a 2006 with original tires. And if yes should I look for oem or are the off brands cheaper and as good. As always great info on this site. Thanks!
Old Feb 20, 2021 | 03:20 PM
saplumr's Avatar
saplumr
Most definitely. The originals have already outlived their life expectancy.
Old Feb 20, 2021 | 03:22 PM
bobeyoung's Avatar
bobeyoung
I have a 2007 and had new ones installed when I got new tires. I was told they last about 8 to 10 years.
Old Feb 20, 2021 | 03:27 PM
FatsWaller's Avatar
FatsWaller
I strongly recommend that you go with AC Delco or Schraeder, who manufacture them for AC Delco. Before they get installed, check the manufacturing date code that's cast on them to make sure they are fresh. To further derisk things, you can program them before they are installed and mounted on the rims.
Old Feb 20, 2021 | 04:11 PM
USA1LBvert's Avatar
USA1LBvert
Thanks everyone. Fatswaller how are they programmed. Never did this before. Thanks
Old Feb 20, 2021 | 04:22 PM
saplumr's Avatar
saplumr
Need the tool. Amazon
Old Feb 20, 2021 | 04:25 PM
USA1LBvert's Avatar
USA1LBvert
Ok just checked Amazon. Only 12-13bux. Thanks all
Old Feb 20, 2021 | 05:11 PM
FatsWaller's Avatar
FatsWaller
Unless you are planning to switch back and forth between two sets of wheels, don't bother buying the tool because any tire shop will have them and should program the sensors as part of the installation. You can still get the shop to program them before they install them. The actual programming takes all of a minute, so they usually don't charge if it's part of an install. You can find the actual programming instructions online. You start by pressing the lock and unlock buttons on your key fob at the same time. The basic programming tool is around $12, so if you like having tools, then it's not going to break the bank.
Old Feb 20, 2021 | 06:23 PM
USA1LBvert's Avatar
USA1LBvert
Ah ok. Wasn’t sure if installer would. Thanks
Old Feb 20, 2021 | 06:39 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
When I needed them I bought from here, been in the car 4 years, with no complaints and the store had computer to set them
https://tpms247.com/collections/2006-chevrolet-corvette
Old Feb 20, 2021 | 06:53 PM
USA1LBvert's Avatar
USA1LBvert
Thanks 1bdvet. Ok stupid question. They say black rubber or brushed aluminum. Any preference?
Old Feb 20, 2021 | 07:02 PM
USA1LBvert's Avatar
USA1LBvert
Yeah mine still work too. But from what I’m reading like you just said they are past their prime.
Old Feb 21, 2021 | 02:19 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
https://www.tpms.com/Huf-Intellisens...uvc0076set.htm
Old Feb 21, 2021 | 10:57 AM
NYC6's Avatar
NYC6
So many have stated only use OE sensors after horror stories with other makers, I went with Cultrag Chevy Performance. Price better the dealer and OE pieces. They are dated made in late 2019.
Amazon Amazon
Old Feb 21, 2021 | 11:24 AM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Make life easier for yourself, buy the reset tool. Believe me it will come in handy..
Dave
Old Feb 21, 2021 | 11:29 AM
USA1LBvert's Avatar
USA1LBvert
Dave yes. I figured it’s not a big investment and I love tools and gadgets. Lol
To Tpms?
