PO455 code
Old Sep 28, 2021 | 06:37 AM
449er's Avatar
449er
CF Community Team
Default PO455 code
I have the PO455 code on my car, I would rather not go to the dealer for this & need some help diagnosing the issue. Start with the gas cap and/or the canister purge valve? Thanks
Old Sep 28, 2021 | 06:45 AM
v4e2r7t's Avatar
v4e2r7t
Try a search on P (numberal zero) 455.
At the moment you have P (letter O) 455, so you may not get results if you searched.
Here is one search result:
P0455 thread
Old Sep 28, 2021 | 08:05 AM
gdmoore01's Avatar
gdmoore01
You are on the right track and may find your answer in the following thread:
https://www.corvetteforum.com/forums...ess-story.html
Good luck and let us know what you find and the fix.
GD
Old Sep 28, 2021 | 02:40 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
This is the basic EVAP Control System failure. First & easiest is to make sure gas cap is tight. Second would be replacement of the gas cap itself. Third is replacement of the EVAP vent solenoid in right rear adjacent to fuel tank....inexpensive part & easy DIY. In each case, you need to drive several cycles after the "fix" in order for the system to reset itself, before going to the next step. Here's more... https://www.carparts.com/blog/p0455-...leak-detected/
Old Sep 28, 2021 | 03:30 PM
449er's Avatar
449er
CF Community Team
Thanks guys for the help
To PO455 code
