Question
Old Dec 8, 2021 | 10:00 AM
Dyson's Avatar
Dyson
1st Gear
Default Question
I went thru a carwash and later that night my check engine light and service traction control code popped up. It was fine before the carwash. Any suggestions on where to start looking to fix and clear the codes
Old Dec 8, 2021 | 10:05 AM
Corvette_Ed's Avatar
Corvette_Ed
What codes did you get? First thing I would check is the battery as that is a common cause for random lights to start appearing on the DIC.
Old Dec 8, 2021 | 10:12 AM
RetroGuy's Avatar
RetroGuy
Was the "car wash" an old fashioned automatic one that pulled your tires through those "directional guide" rails? Hope not. That would cause a lot of potential tire/wheel issues even if it could fit into those tight rails. Your CEL could be from water spraying into the engine getting onto the battery and into the air intake, or...many other quirky related moisture issues. I always wash my Vette myself and very careful not to spray any water directly into the front end.
Old Dec 8, 2021 | 10:26 AM
C6ToGo's Avatar
C6ToGo
At minimum, I would own a $17 code reader that will show DTCs and clear them. At the very minimum, you can go to your local auto parts store and have them read it for you. But, like me may years ago, if it takes forever for them to come out to your car....and then they didn't clear the code like they said they did, you will find your own code reader to be $17 well spent.
Amazon Amazon
Even better is a $100 OBDII scan tool that reads more errors....like ABS (brake) and SRS (airbag) codes.
Amazon Amazon
If you come back on here with codes, be sure to also mention your year model and engine size.
The links I gave are the two I have that work well, in addition to a GM Tech2 for more diagnotic capabilities. Many OBD2, CAN-enabled, readers and scanners to choose from.
Old Dec 8, 2021 | 10:46 AM
blownbayou's Avatar
blownbayou
Old Dec 8, 2021 | 12:10 PM
jbc1995fb's Avatar
jbc1995fb
That's your car's way of telling you that you shouldn't run your car through the automatic car wash.
Old Dec 8, 2021 | 02:36 PM
Iceaxe's Avatar
Iceaxe
Your Corvette should go through a car wash just fine, despite what many in this forum believe, at the end of the day it's just like any other old Chevy. Pull the error codes and than you will know where to begin looking for the problem
Old Dec 8, 2021 | 05:37 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Wait a few days for things to dry out. If you still have problems after say 4 days, then worry.
Tom
Old Dec 8, 2021 | 07:00 PM
dpigguy's Avatar
dpigguy
If it was a full service car wash or you vacuumed the floorboards as part of the clean up, check the fuses under the passenger side carpet. Ensure they are all seated correctly. Also check the yellow connector under the driver’s seat as it can work loose and disconnect as well.
Old Dec 8, 2021 | 10:20 PM
buckmeister2's Avatar
buckmeister2
Well, it would if the tires fit. I have not found one in LV that can the width of tires on the base C6. Wait, let me restate the...the only one I found was the brushless (spray jet only), and that would barely knock off the dust, let alone any road grime.
Old Dec 8, 2021 | 11:08 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
As stated above let things dry out a bit. Perhaps take it for a looong drive to get everything up to temps. It may take a start/stop cycle after that to reset or, perhaps, a battery disconnect for a couple minutes. I occasionally run mine thru a park it and brushless wash to get the dust off.
Old Dec 8, 2021 | 11:38 PM
C6 Snowboarder's Avatar
C6 Snowboarder
Old Dec 8, 2021 | 11:57 PM
Iceaxe's Avatar
Iceaxe
I have no clue about LV, but I know a Z06 will go through Quick Quack and Mr Wash in Salt Lake and both do an excellent job for a drive through. I'm sure you'll see a Quick Quack soon in Vegas as a new one goes up about once a week in Utah and CA.
While I normally hand wash my Corvette's I will say the new generation of drive through car wash that began showing up about two years ago do a nice job when you're in a hurry.
YMMV
Old Dec 9, 2021 | 12:07 AM
Iceaxe's Avatar
Iceaxe
Just for fun I asked the new Quick Quack car wash down the rode from me what their tire restrictions were. They said as long as the tires are 345 or narrower they will go through.
Old Dec 9, 2021 | 05:30 AM
449er's Avatar
449er
CF Community Team
See #5
Old Dec 9, 2021 | 07:14 AM
jjfabs's Avatar
jjfabs
A Corvette might go through some but not all. It is a simple car to wash because it is so small, why take a chance?
Old Dec 9, 2021 | 10:17 AM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
Not everyone has access to a hose and car washes are convenient. I'll occasionally go through the touchless automatic car washes if I find one but there aren't any near me. I've never been though the ones that you drive into the tracks and they pull you through. I drive 45 minutes to the nearest car wash that has the high pressure wands.
To Question
Old Dec 9, 2021 | 10:23 AM
Iceaxe's Avatar
Iceaxe
I'm not advocating for running your Corvette through a car wash. But I am laughing at how many on this forum believe the Corvette is some delicate and fragile vehicle. The Corvette is made by the same company that makes Tahoes and 2500 Series trucks that can be priced similar to a Corvette, yet are seldom babied and often used on work site and extreme environments. At the end of the day the Corvette is still just another old Chevy
Old Dec 10, 2021 | 08:32 AM
v4e2r7t's Avatar
v4e2r7t
But you paid the upcharge for the distilled and ionized Belgian water, right?
Old Dec 10, 2021 | 08:34 AM
blownbayou's Avatar
blownbayou
Originally Posted by 449er
See #5
Stealing this
