Google Maps has an offline mode where you can download a cached copy of the maps for areas where you might have spotty reception. I do this whenever I'm going on a driving trip, and I keep several areas that I visit frequently (i.e. my parents area) as permanent offline maps.
Correct me if I'm wrong however I believe there is a difference between cell reception and GPS signal, I wonder if you lose one does it still loose the other. That would be independent of unit I presume.
C4 of Year Winner (performance mods) 2019
Loosing cell service does not impact GPS. The phone and Google Maps will function (if you have offline maps), you just won't get your history and suggestions.
Ah I see. So the debate would be how accurate is your GPS, regardless of unit. Interesting, I use the phone on some mount in another car so great to know.
However personally I still prefer the utility of a dedicated unit, hard to beat when it comes to it.
I know there are no updates for the C6 navigation system but has anyone found a way to update it other than the normal commercial update (which has no updates).
Has anyone tried to update the system using another cars disks to update the C6, such as something from Camero, Caddy, GM, etc.?
I do not want to use something other than my factory system, such as Garman, etc.
If you have solved this problem please post your results.
Tks
The newest disk I’ve installed in my 3LT was the 2016 Version 10.0c purchased on Ebay. When listening to CD’s and radio stations, I only use the Nav Screen as an alternate display screen. The Apple iPhone NAV APP is my best up-to-date NAV program with coast to coast directions, gas, restaurants, etc...GM needs to work with Apple and Android Nav APP's to offer an “auto-updating software sharing deal" in their higher end dash head units.
I once ran a long trip in a 2010 C6 which was mainly on secondary highways. The stock NAV system ran me all over the place. I since learned to go point to point with the stock NAV in shorter distances.
Or look at an actual map once you are close set the address.
I actually find it very annoying to watch a map or listen to someone speak directions when I am driving. I use google maps on my phone to determine a route. As said above I don't activate the navigation until I am close to the destination. YMMV
I'm not very cell phone proficient I must admit (hate the damned things) but I've had problems with the phone automatically deleting the downloaded maps and only allowing a relatively small area of maps. Much prefer to have a permanently installed map of the entire north American continent.
I’m 100% with you on this. I’ve got an older Garmin that works just fine. I can create multi stop trips with several products and use BaseCamp to load them into the Garmin, or just use BaseCamp to create them. A lifetime map update came with it, so it’s always pretty much up to date. I mount it low on the windshield so it just rests on grill in the dash pad and can’t get jarred out of alignment, and it’s in my sight line so I can keep my eyes on the road.
The discussion seems to divert to navigation here, I think it's interesting that Google maps works better in some areas, like diverting for traffic plus building accuracy, yet Garmin works better in some areas like 3D maps junction views and ancillary information. Both updated easily, both don't have to look away from the road. I prefer Garmin even though periodically I use my phone.
