C7 Seat Install Guide
I bought the seats having done about half the research I should have but a deal came up and I was committed to getting them in as factory correct as possible. I wish the side airbags could have been retained. I explored swapping the C6 bags into the C7 seats but that would have required more wiring in a system that is very sensitive to wiring changes.
Ventilation is noticeable and worth it in my opinion. There is a known issue with C7 seats that you would want to try to check on any pair you are buying. The wiring for the fans is integrated with the heating elements and over time, those wires can get pinched or frayed within the seat. If this happens, the vent fans either will not work or will work intermittently. Only way to fix this is to order a new seat heating element and swap it out.
I know the C7 seat is a bit heavier, but it is because the Lear design has a nice proper frame. I'm just curious if it is something you notice with longer drives or with spirited drives.
Great write up though, I'm sure this will help others do this change.
Thank you. One update is that I forgot I normally drive with the sun visors flipped down and all the way forward. Last week I flipped them up to the standard position and I can see lights normally again without leaning forward.
I can confirm with 1LT you don't have to deal with the side airbag sims, but you will have to bring 12V power to the passenger seat. The seat circuit (at least driver seat) is always "HOT" in the C6, regardless of key position. I chose to power my driver seat movement with the stock C6 seat power circuit (always on), and I built an
I reused the C6 occupancy sensor in the C8 seats and it hasn't impacted the seat cooling fans. I occasionally do parades/sunday drives with my young children so a functional airbag "off" sensor was important.
@_Rod_ figured out a way to swap the C6 seat position sensors onto the C8 seats, I copied this and it works flawlessly so far. Vetteworks makes sims for this, but I preferred to do what Rod did.
Still love the seats.
Getting in and out is a little more tricky with the more aggressive bolsters but there's no way around that. I can understand now why C7s have entry/exit seat position settings to make it easier.
I just got back from an almost 2000 mile road trip that I also did in 2021 and can say these seats are better in every way than the C6 seats.
I thought the firmness of the bottom cushion would be an issue but I think the extra support was actually better for me. I was more sore and ready to get out of my C6 seats in 2021 than I was in these C7 seats 2 years later. I spent about 6 hours in them without getting out during one stretch of the trip and have no complaints.
I keep the passenger seat belt buckled to stop the "buckle passenger" warning since the occupancy sensor is rolled up and the car always thinks there's someone sitting there. I may end up crafting a dummy seat belt plug that I can put into the seat belt receiver to stop the alarms.
