C6 Winter Storage
Old Oct 14, 2023 | 09:17 AM
  #41
Rempt's Avatar
Rempt
Thanks guys! I live in a condo complex so no choice when it comes to the maintainer at this point, so all your suggestions are really helpful! I appreciate it!!
Rich
Old Oct 14, 2023 | 04:50 PM
  #42
HOXXOH's Avatar
HOXXOH
The other option is to store it a couple hundred miles South of NY (NC/SC/FL/GA) and visit it for a day or two each month to ensure it gets some love and care.
Old Oct 15, 2023 | 10:44 PM
  #43
R.Evans's Avatar
R.Evans
The “car capsules” work very well. It’s a pain in the *** to get them in and out but for winter storage they are great. There is a place to route a cord for a tender. I keep my c6 and c4 in one and zero rodent problems or holes chewed in the capsule. I live next to a field in iowa and mice are a problem. They are 500 bucks on Amazon or their website. Get one if you are on the fence. They help me sleep at night knowing a rodent isn’t chewing on my wiring….
Old Oct 16, 2023 | 11:29 AM
  #44
rentedmule's Avatar
rentedmule
I store mine in a barn that's been converted for use as a garage and it has wood plank floor. I screw a tarp down onto the floor before parking it for the winter to stop condensation from developing on the underside every time there's a change in temperature.
Otherwise, I add fuel stabilizer, fill the tank, drive a few miles, and then I disconnect negative terminal and put the battery on a tender for a week once every 2 months.
Old Oct 16, 2023 | 01:50 PM
  #45
oldcanuck's Avatar
oldcanuck
If you have to park outside I'd recommend removing battery until the spring. You can then re-install it and it should fire up.
You probably need to leave the hood popped so you can open it when needed.
If you live in a condo is there no access for parking ?
Sometimes you can rent an indoor parking spot from someone who has one but doesn't use it.
Old Oct 16, 2023 | 06:57 PM
  #46
dr_gallup's Avatar
dr_gallup
Don't leave the hood popped! Make sure you can open the hatch/trunk with the key. Assuming you can, then locate the door release cable. With that you can get in and open the hood release.
