Fuel Pump Replacement
Naples FL
What is the recommended replacement parts for 2006 Z51 Convertible?
what parts are needed and any additional parts worth replacing while tanks are out?
what vender? Which manufacturer?
RockAuto list’s GM pump for left side and it also list the same for a convertible??
Received 1,129 Likes
I have accumulated parts for my 07 for when I need it:
Left tank pump (may or may not include the fuel level sensor/sending unit)
Left tank fuel sensor ( be careful.....05-06 sensors are different from 07+)
Left tank fuel feed hose (these mounting tabs can break when you pull crossover tube out)
Right tank pump
Right tank fuel sensor ( be careful.....05-06 sensors are different from 07+)
Right tank fuel feed hose (these mounting tabs can break when you pull crossover tube out)
Crossover tube with feed tube included. (maybe not needed but a lot say that reinstall is easier with a new crossover tube that is not stiff from age)
2 sets of crossover tube o-rings, not included with crossover tube.. (only thing I haven't bought cause 50 bucks which sucks for 4 o-rings and can likely be reused)
Maybe have the left tank fuel pump wire connector as have read that they can be messed up. $28 no-name on eBay.
Right tank pump
