Key FOB programming with Tech 2
Also number #1 will not pop the hatchback. If I just add it to #3, I don't believe it can do that function (pop the hatchback).
So I am using this procedure: https://www.corvetteforum.com/forums...-question.html
I am right at the point of invalidate all FOBs. What happens if things go wrong? Will I have to tow the car to the dealership?
More complete than the owner’s manual, but I’ve seen it written a few times that in addition to those instructions, you may need to complete the procedure for each fob by pressing the unlock button on it.
The factory FOB has been solid thus far compared to the #1 knock off. That one wouldn't pop the hatchback.... and was also, at times, unreliable.
Short of an export car, where you have a waiting period before you can program a fob in tech II type tool,
with Tech II, can program fobs into any slot (even if currently being used by another fob), where as when you use the long procedure with key to first erase the fobs then program them back in with 30min wait time, so you can program then back into cleared slots, While short procedure is only going to allow you to program fobs in to the 3 or 4th unused slots.
Hence with tech II, and car not export model, should only take about 3 mins, first to erase all fobs that are programmed in (so a fob floating around that someone else has, can not be use to steal the car), then program in the fobs into the slots that you want them in. Hence car with memory functions, only slot 1 and 2 will work with these momory features, and slots 3 and 4 on the RCDLR will not.
As for is you screw something up while programming, and do not even get a single fob programed in, so you can put the car into ACC mode to use the Tech II, then need to use SPS to put the RCDLR into relearn mode, so when you press the start button, DIC will ask you to insert the first fob to start programming.
Note, export cars, or using TIS2000 SPS, going to have the 30min wait time, hence 3 10min count downs, where once the two 10min count downs go to zero, will need to hit the starter button again within 1 min, to start the next 10 min count down.
Simply, for export models, the count down is to make it harder for someone to get into the car to program a new fob in, so they can steal the car with new programmed fob.
Same for someone using stand alone TIS2000 with count down for both usa and export cars, while on line TDS SPS, no wait once RCDLR is put into relearn mode.
