C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Aviaid Baffle install
Old 05-16-2010, 11:06 AM
danbo56
danbo56's Avatar
Default Aviaid Baffle install
Does anyone have a good set of instuctions for the Aviaid Baffle install on a 07 C6Z? Pictures would be even better. I have the LPE tank in place do I need to pull the tank of just the top?
thanks in advance
Old 05-16-2010, 11:39 AM
slief
Support Corvetteforum!
slief's Avatar
Try this.. Never heard of them or this.. After I googled it, I see they are (or where) located a couple doors down from my office.. Who'd a thunk it.
Old 05-16-2010, 11:41 AM
wstaab
wstaab's Avatar
You will need to pull the tank.
Instructions: http://www.aviaid.com/pdfs/z06-instructions.pdf
Oil pan insert.
Stock windage tray modified to fit.
Old 05-16-2010, 06:56 PM
JDIllon
JDIllon's Avatar
I assume you mean the Tank baffles? If so, Yes you should pull the tank. Trying to do it from the top will take you longer than pulling the tank. JD
Old 05-16-2010, 09:54 PM
danbo56
danbo56's Avatar
thanks fellas! That will get it!
Old 05-17-2010, 01:47 PM
jlutherva
jlutherva's Avatar
Danbo, did you get what you need? I installed the Aviaid dry sump tank baffle in a 2009 tank for my 07 Z. I can walk you thru it.
Jim
Old 05-17-2010, 03:10 PM
jlvink66
jlvink66's Avatar
thanks in advance
Yes, you will need to pull the tank out to get to all of the screws. Here is a photo from when I did mine. The instructions from Aviaid on installing the baffle in the tank is pretty good;
Dreamin did a great write-up on installing the tank;
http://forums.corvetteforum.com/c6-z...tallation.html
John
Old 08-05-2012, 03:48 PM
dvandentop
dvandentop's Avatar
wstaab just curious as to why you modified the stock windage tray???
i have read that it is necessary to remove the stock one when using the baffle?? I am working on the install now so any replies appreciated.
thanks
Old 08-05-2012, 05:20 PM
SLandstra_Z06
SLandstra_Z06's Avatar
Derek,
I installed all of those parts when I had the new engine put in my car last month. Also, the Katech hi-flow ported and blueprinted oil pump.
Steve
Old 08-05-2012, 06:36 PM
dvandentop
dvandentop's Avatar
yep i am going to be using the katech pump, the tank insert, lingenfelter tank and also the pan insert.
just confirmed with John from Aviaid that the stock windage tray is not necessary on the ls7 pan install
Old 08-05-2012, 06:58 PM
SLandstra_Z06
I didn't put the stock windage tray in, but all of the Aviaid sheet metal parts and the tank insert.
To Aviaid Baffle install
Quick Reply: [Z06] Aviaid Baffle install
