[Z06] Sound made when oil tank screen comes loose?he
Received 8,993 Likes
Was working on the car today reved engine in neutral to about 1500 rpm and started hearing an irregular popping sound coming from the dash. The noise was similar to what you hear when the water starts to boil in a tea pot. This is the first time I have heard the noise and was wondering if this is the noise people heard when the screen inside the oil tank came loose. Oil tank was taken apart and cleaned 4500 miles ago when the engine was replaced.
Bill
Bill
Somebody must remember what this sounded like? It's only been 3 or 4 years.
Bill
Bill
hey bill, i remember mine. it came loose early on my car. it was kinda like marbles in can. i also just asked my wife, cause it used to drive her nuts as well and she agreed on the type of noise. hope this helps. in this case maybe they left the o-ring out, or it got lost when it was apart. easy and pretty much a free repair as you already know.
Check out the video I posted in my thread about the same rattle. This rattle was, in fact, the o ring.
http://forums.corvetteforum.com/c6-z...nk-rattle.html
Bill
Oil tank tube is loose. Confirmed today. Can actually feel it rattling around inside the dry sump.
Cost $287 to fix. GMPP doesn't cover the repair.
Bill
Bill
You can do it in ~4 hours, no problem.
Why does GMPP not cover it? Do you have Major Guard?
Bill
I haven't had to use GMPP yet, but this doesn't sit well.
At any rate, I'm glad you identified the issue.
That's surprising. Are you going to push the issue? I also purchased Major Guard and by the exclusions listed on their paperwork, this is something that should be covered without question.
I just called GMPP and talked to their representative. He said sometimes dealers use a GM Labor code that gets denied but I should have them call the claims center and explain what is being repaired and it would probably be covered.
Bill
I have used it several times and have received about half of my original $2500 investment back.
Bill
Bill
Please don't pay to have this fixed
DH
yea there is a tsb on it from what i remember. ill check. besides that i remember having a discussion about the tube being loose and possibly causing the oil to foam up in the oil tank from aeration. i think its def. possible especially with the lower end issues zo6s were having during track days....somethjing to think about and yes def. fix it. bill im sure your capable of fixing this yourself or atleast know a buddy that can help. wish i were closer i would do it for you.
Service Writer used the labor code from the TSB and I saw the return message from GMPP. It was a correct description of the repair and said it wasn't covered. That was the discussion I had with the GMPP rep. He said that sometimes that the electronic process doesn't work correctly.
I thoroughly expected GMPP to pay for it and that still may happen. I really don't have the time and the place to do it myself as I plan on driving the car to Sebring two weeks from now. Have a bunch of other things to do before I leave. It is also difficult to work in a cramped 2 car garage, with bad lighting with the inside temperature running 40 degrees.
Bill
Bill
Just got back from picking up the car. Repair will be covered by GMPP. Service Writer called and the rep he talked to said it isn't covered so he said a Customer just said he talked to a rep and that person said it would be covered. Rep puts him on hold and after some time the rep comes back and gives the Service Writer a work around claims processing procedure to enter into the computer and the repair on my car is now covered. Part should be in tomorrow or Monday.
Bill
Bill
Bill
Bill
DH
