C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] 2.45 Griptec Pulley Belt Size
Old 01-24-2020, 11:11 PM
2200HP
2200HP's Avatar
Default 2.45 Griptec Pulley Belt Size
I plan to switch from a 2.6 with stock lower to a Griptec 2.45 and also stock lower. Anyone used or are using this combo? I need to know belt size and idler pulley size. Thanks
Old 01-25-2020, 08:33 AM
9sec
9sec's Avatar
I found the green belt on eBay for 45$ shipped. cut 1 rib off and also found a ligenfelter 76mm idler pulley for 80$ shipped. belt part #gates k120842hd.
https://www.ebay.com/itm/GATES-K1208...oAAOSwS~ReDS~0.
Old 01-25-2020, 08:43 AM
StealthFRC
StealthFRC's Avatar
I’m pretty sure I ran the stock belt with a different idler.
Old 01-25-2020, 02:45 PM
JMBLOWNWS6
JMBLOWNWS6's Avatar
K120842hd. Remove one rib. 76mm idlers on both sides with a 14% lower
Old 09-04-2020, 12:17 PM
mdopole1
mdopole1's Avatar
im looking at this combo. What idler pulley belt did you end up with?
Old 09-04-2020, 03:23 PM
2200HP
2200HP's Avatar
I decided to go with 2.35 instead.
To 2.45 Griptec Pulley Belt Size
Quick Reply: [ZR1] 2.45 Griptec Pulley Belt Size
