C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Why is this attached to my positive battery cable?
Old 12-10-2023, 10:00 AM
Whoop
Whoop's Avatar
Default Why is this attached to my positive battery cable?
I previously had a C6 Grand Sport so I'm familiar with the rear battery location. I replaced my ZR1 battery yesterday since I purchased the car 3 years ago. I notice this "extra" piece on the positive connection that I don't remember seeing on my GS. Is this a ZR1 thing?
The car doesn't have anything extra electronically that I'm aware of, no aftermarket head unit or other stereo upgrades except someone added a rear camera to the stock unit.
Old 12-10-2023, 10:47 AM
Ravenrider1k
Ravenrider1k's Avatar
Pretty sure it’s for fuel pump since these cars have a controller for them
Old 12-10-2023, 01:39 PM
Too-Fast
Too-Fast's Avatar
Not on my 2011 C6 Z06.
Old 12-11-2023, 09:59 AM
Texasthunder
Support Corvetteforum!
Texasthunder's Avatar
My 2010 ZR1 doesn't have it.
Old 12-11-2023, 10:45 AM
leadfart
leadfart's Avatar
My 2011 has it. It is factory, whatever it is.
Old 12-11-2023, 10:51 AM
Ravenrider1k
Texas thunder strange my 2010 has it
Old 12-11-2023, 12:30 PM
Colonel
Colonel's Avatar
My bone stock 2011 ZR1 has it.
Old 12-11-2023, 03:26 PM
Texasthunder
Well shoot. Now I'm going to look at mine when I get home from work. I don't remember it from when I changed the battery.
Old 12-11-2023, 08:55 PM
Rokket
Rokket's Avatar
My 2009 ZR1 has one.
Old 12-12-2023, 09:41 AM
Texasthunder
CORRECTION!! Went home last night and looked at mine and it does have it. Thanks OP, now I want to know what it's for.
Old 12-12-2023, 08:00 PM
Colonel
Colonel's Avatar
My 2012 ZR1 Centennial has it as well.
So......WHAT DO IT DO?!?
Old 12-12-2023, 09:45 PM
Heatman
Heatman's Avatar
For battery tender I’d say
Old 12-13-2023, 07:46 AM
Nosferatu333
Nosferatu333's Avatar
you have to look under the carpet. Mine had it but I only noticed it when I took the entire carpentry out. Mine is an 09 zr1. I suspect they changed the location at some point to make it more accessible
Old 12-13-2023, 07:58 AM
Rokket
Rokket's Avatar
As Ravenrider stated it is a fuel system mini fuse.
Old 12-16-2023, 05:42 PM
passagemaker43
passagemaker43's Avatar
Just a little side note here a little off the OP's question. Had my 2010 stock ZR1 for almost 5 years till I sold it last year. Unique to the ZR1 compared to the Z06 for instance is the factory limited charging voltage to roughly 13.8 volts compared to about 14.6 for the Z06. I can tell you over time that voltage falls short of what is necessary for full charge and longevity. My specialty was marine 12 volt systems where people depended on them for all onboard systems when offshore and in distant lands. GM wouldn't allow that override voltage limitation to be changed at a factory dealership. Certainly a good tuner could reset it. Despite using a battery tender, every month or two I put a digital charger on my ZR1 and let it fully charge the battery to 14.6 volts (assumes 77 degrees ambient battery temperature). Could add years to the life of your battery if you keep a tender on it as well.
Only found that restriction on my ZR1, not on any of my other Corvettes. Never could confirm a reason for that driving voltage reduction compared to the Z06.
Just my 2 cents.
Keith
Old 12-16-2023, 07:53 PM
leadfart
leadfart's Avatar
Anyone know if you can change the settings in HPtuners? Be nice to get full power out of my fancy fancy aftermarket alternator.
Old 12-17-2023, 11:30 AM
Whoop
Whoop's Avatar
Thanks everyone for confirming. You never know on a used car with previous owners what has been added or not.
To Why is this attached to my positive battery cable?
Quick Reply: [ZR1] Why is this attached to my positive battery cable?
