C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
it has started.......
Old Feb 19, 2008 | 02:07 AM
blu00rdstr's Avatar
blu00rdstr
Subscribed!
Similar to my build:
  • LS3 block
  • Callies Compstar Crank & Rods (3.622" stroke, 2" journals)
  • Diamond L92 pistons -12cc dish coated
  • LS3 heads mild port job (smoothing & polishing)
  • Comp 921 springs, Manley stainless intake valves
  • '08 Z06 cam -or- existing TR blower cam
  • L76 manifold
  • D1SC
Coated pistons:
I just noticed your piston pics show there's meat under the oil rings. Only stock stroke pistons have material there, the stroker pistons require an oil support ring. Is that the correct piston?
Old Feb 19, 2008 | 06:12 AM
excessive81's Avatar
excessive81
they have a oil support ring. guess the pic at a bad angle
some notes:
416 ls3 with dragon slayer crank, compstar rods and je pistions require no clearancing of the block.
thought i had a issue with last piston when checking but i was just using one piston to check for clearance. piston 8 caught on something. i clayed it and it was the reluctor ring. swapped to the right piston for the hole and it cleared!!!
Old Feb 21, 2008 | 01:02 AM
Brabus2's Avatar
Brabus2
Bringin on the heat, balln.
Old Feb 21, 2008 | 09:01 AM
excessive81
brabus whats up how is your beast running. have not heard anything in a while. you get the turbos ironed out?
Old Feb 21, 2008 | 02:33 PM
Skunkworks's Avatar
Skunkworks
Looks good so far, did you notice the core shift found on earlier block?
Mike
Old Feb 21, 2008 | 05:56 PM
blu00rdstr's Avatar
blu00rdstr
A question for you excessive81, did you at one point consider LS7 heads and intake? It seems the L92/L76 (LS3) combo is rpm restricted and the canted valves of the LS7 make a big difference in flow. However I think there's a minimum bore size restriction on the LS7 heads (I forget what it is).
Also, are you going with stock sized head bolts or thicker studs?
My L76 manifold doesn't have the bolt hole for the MAF sensor, hmm.
Old Feb 21, 2008 | 06:11 PM
excessive81
no i never considered the ls7 heads as i got these ls3 ported heads at a killer deal. i started out just doing a rotating assembly...then bought a block....and it snow balled into where i am now...lol my intake is an actual ls3 and there is a bolt hole i am pretty sure. also i am using arp 12 pt main and head studs
Old Feb 21, 2008 | 06:13 PM
excessive81
your right. look back at first page i posted pics comparing ls3 and l76 and i didn't notice it but the l76 dont have a bolt hole....the ls3 intakes do
Old Feb 21, 2008 | 06:30 PM
excessive81
Old Feb 21, 2008 | 07:31 PM
C6dude's Avatar
C6dude
Looks like it's coming along good Shane.
Old Feb 21, 2008 | 09:03 PM
excessive81
well it was...got a bad rod so in holding pattern agian....
Old Feb 21, 2008 | 09:30 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Damn Bro,,,,that's alot of stuff!!
Old Feb 21, 2008 | 11:39 PM
  #33
Mr.Big's Avatar
Mr.Big
Old Feb 23, 2008 | 02:30 PM
  #34
excessive81
comp cams ecs blower cam
Old Feb 23, 2008 | 02:34 PM
  #35
excessive81
comp cams ECS blower cam
comp cam double roller adjustable time chain
Oh yeah....6.2 liter ls3/l92 block streached to 416 ci!!!!
Old Feb 23, 2008 | 03:17 PM
  #36
C6dude's Avatar
C6dude
Hey Shane,
Looks good bro.
One thing that I noticed about your 2 row timing chain. The cam gear specifically.
It does not have the raised steel imprint for your cam sensor to pick up the position of your cam.
I think it's the wrong chain bro. Luckily the motor is not in the car.
You better check into that.
Here's what I mean. Note the difference ?
Perry
Old Feb 23, 2008 | 03:31 PM
  #37
excessive81
i was just looking into that... the ls1 has cam sensor in the back of the block....ls2 it moved to the front cover....it is the wrong one...bummer!!!!
To it has started.......
Old Feb 25, 2008 | 10:42 AM
  #38
excessive81
lifter trays modified
comp cam lifters in
trays in
oil deflector with modified holes to fit arp studs
pluging it up
heads bare
with rockers and pedastals in
cnc ported....
....getting close....
Old Mar 10, 2008 | 11:01 PM
  #39
excessive81
after a little break to work on some customer cars i took a day to finish my motor. hope to get it in car next week....
rod bolts stretched to .050
correct timing set
new arp cam retainer bolts and cam bolt.....just for you indy car sceen
xhecking timing
rigged up stretch gauge to read valve lift from lifter
clayed for valve clearance.....didn't even touch it under .600 lift
Old Mar 10, 2008 | 11:07 PM
  #40
excessive81
heads back on for good
manley push rods
rockers in
valve covers
yup supercharged lol
complete....
now i will pretty up a few things and nuild custom fuel rails for it
