C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
aps dyno
Old Jun 5, 2008 | 07:14 PM
  #41
atomicC6's Avatar
atomicC6
Originally Posted by FastBlackTA
I rebuilt the stock motor with the stock crank and used manley h lite rods with mahle pistons. GT11 cam with stock heads. (basically cost me 2k for parts to rebuild the motor....not too bad).
I have the forge actuators in there now, but my inlets are hooked up as I drive the car a lot. I have readjusted the actuators and have not been able to hit the dyno yet. Maybe next week.
Congrats and Keep pushing that thing - these cars are real quick with 700+ rwhp!
thanks you know ill keep pushing it ,none of us can ever have enough power .......2k thats not bad at all.i bet you cant wait to crank up the boost and see what it will do (of course it will do better if we ever get this inlet issue fixed.)let us now when you do it.did you drop the motor out the bottom on a lift or did you take it out the top?did you just stick pistons in or did you send the block off and get it bored? shaun
Old Jun 6, 2008 | 01:12 PM
  #42
FastBlackTA's Avatar
FastBlackTA
I dropped the motor off at my machine shop for honing, they had the block ready for me to assemble in 2 days (which is quick for machine shops around here). The pistons were 4.005.
For now, I would just like to see 700+ with the inlets hooked up, then when winter comes maybe some inlet changes.
What fuel system are you using?
Old Jun 6, 2008 | 05:14 PM
  #43
LMBC6Brian's Avatar
LMBC6Brian
Originally Posted by vegasredz062
that is one of the nicest charts i have seen on an APS C6 car!!
How can you say this when his a/f is in the toilet for the first half of the rev range. Its running pig rich??
Old Jun 6, 2008 | 05:35 PM
  #44
vrybad's Avatar
vrybad
Ummmm, you need to take a look a bit higher, at the tq and hp lines.
Sure, a/f could be cleaned up a bit down low, but overall, that chart kicks a$$!!
Old Jun 6, 2008 | 05:38 PM
  #45
Mr.Big's Avatar
Mr.Big
uuuuuhhhhhh ALKY... You have a different AFR with methanol...
Old Jun 6, 2008 | 06:35 PM
  #46
LMBC6Brian's Avatar
LMBC6Brian
With alky I can understand. Without, alky that is a bad a/f there. No matter what hp/tq it makes, you want it to be safe and running that rich is not as bad as being lean at all, but still not good for the car.
Old Jun 6, 2008 | 09:07 PM
  #47
atomicC6's Avatar
atomicC6
im just using 60 pound injectors and a kennebell boostapump.and i have the AIS dual nozzle alky kit.
Old Jun 7, 2008 | 11:23 AM
  #48
FastBlackTA
Basically same setup here - 60 lbs, MSD boost, and Alky control dual nozzle.
Old Jun 8, 2008 | 11:07 AM
  #49
atomicC6's Avatar
atomicC6
let me know when you take it back to the dyno and crank the boost up, .
Old Jun 10, 2008 | 05:49 PM
  #50
99Silverbullet's Avatar
99Silverbullet
CI 8 & 9 Veteran
C2 of Year Finalist (performance mods) 2019
St. Jude Donor '07-'08
man thats awesome..yah i'm having the same problem with my car no getting anything at high boost..having my car put back on the dyno tomorrow and unhooking those inlets to see what it does..mine dies off at 9psi..don't know why..keep you guys updated
Old Jun 10, 2008 | 09:44 PM
  #51
atomicC6's Avatar
atomicC6
are you saying that it wont make over 9 psi or its not gaining anymore horsepower after 9 psi.you should be able to make over 9 psi but after a certain psi you wont gain any more horsepower(not enough volume of airflow through the inlets).do keep us posted
Old Jun 10, 2008 | 10:06 PM
  #52
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
Yes, hes running out of AIR on those inlets..once he runs the car on the dyno with nothing on them.. watch out.. 800rwhp+..make sure you have the right fuel. and ofcourse clutch will have to hold.
Old Jun 10, 2008 | 10:32 PM
  #53
atomicC6's Avatar
atomicC6
Sam,hows it going? have you heard anything from Peter on you inlets?i figured he would at least chimed in on this thread since it was about APS.
Old Jun 14, 2008 | 01:01 AM
  #54
Z06Samuel's Avatar
Z06Samuel
Madboost, I like those inlets!
Sam
Old Feb 4, 2010 | 09:11 AM
  #55
C6 Twin Turbo's Avatar
C6 Twin Turbo
Default APS pipe
Originally Posted by MadBoost
Here are a couple of pictures of a little routing project we did a couple months ago. This was specifically a fitment exercise and we didn't attempt turning the boost up because the current 670rwhp is still more than the car, suspension, tires, etc... can handle on a road course. Ultimately we had wanted to change the comp cover to a 70mm inlet connection and run the 70mm back section of flex tubing, replacing the 63mm, but didn't have time to organize the pieces before the car had to leave. It had seen 715+rwhp on the stock APS inlets previously on our dynojet with 345 Hoosier R6's sticking to the rollers but as I mentioned, the power simply could not be put to the ground so we turned the boost back down. Hope this helps some of you out that want to clear that 725rwhp air inlet hurdle....
[IMG]http://i43.photobucket.com/albums/e358/MadBoost/APS/IMG_
0734.jpg[/IMG]
Did you ever get a fix for the APS pipe restrictions?
Thanks for any help
Kevin
