C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Some Centri Info
Old Oct 20, 2008 | 10:23 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Some Centri Info
Vortech=Paxton
I'm not sure how common knowledge this is but Paxton and Vortech are under the same umbrella. I didn't realize this until I got my Paxton head unit back from rebuilding and it had Vortech packing tape on the box. After talking with Paxton/Vortech I now know that a Vortech S-Trim is the same as a Paxton 1200 and a Vortech T-Trim is the same as a Paxton 1500 with respect to bolt pattern, external and internal dimensions, impeller, etc. So if you hear someone say Vortech is better than Paxton or vice versa they are misinformed.
Air Flow
Procharger:
P1 - 1200 CFM
D1 - 1400 CFM
F1A - 1650 CFM
Vortech:
S-Trim - 1000 CFM
SQ-Trim - 1000 CFM
T-Trim - 1200 CFM
Ysi - 1600 CFM
Paxton:
Novi 1200 - 1000 CFM
Novi 1500 - 1200 CFM
Novi 2000 - 1400 CFM
Novi 2200 - 1450 CFM
1000 CFM = 680 supportable HP
1200 CFM = 825 supportable HP
1400 CFM = 925 supportable HP
1600 CFM = 1200 supportable HP
There is some debate about the supportable horsepower numbers, some believe they are artificially low, but it's safe to say that more is better, to a point. So on paper the advantage would seem to go to ATI but one would need to look at the compressor maps to see which would be better for a given application, although thats impossible, see below.
Vortech/Paxton compressor maps - http://www.vortechsuperchargers.com/...pressor%20Maps
Procharger compressor maps - Quote from ATI Tech Support - "Our engineers do not use compressor maps, we do all of our testing in real-world scenarios."
Gears
I'm sure everyone knows that Procharger uses straight cut gears which tend to make the "marbles in a can" sound, particularly at idle. Vortech/Paxton use helical gears which are much quieter and the helical gears prevent the gear backlash which is the source of the ATI marbly sound. I've owned a Procharger on my C5 and now have a Paxton on my C6 and much prefer the sound of the Paxton. All it has is a slight whistle.
Lubrication
ATI is strictly self contained. They do not make an oil fed version. Vortech and Paxton offer both so you can pick your poison. When comparing the self contained units its interesting is that Paxton/Vortech have a breather at the top to relieve pressure in the gear case. Procharger does not. I'm not sure which is better but it's worth noting. Something else to note about the Paxton/Vortech units is that they are meant to be laid with the transmission at a 45 degree angle. So if you were to fill the unit on the bench with the dipstick straight up it would be overfilled by 2-3 oz (4 oz being a full fill). It's meant to be filled and checked as it sits in the car. If it's overfilled oil will leak out of the breather something fierce. There are other Paxton/Vortech units meant to be laid at 50 degrees so if you pick one up at a swap meet it would be worth a call to find out which it is.
Also, for engine oil fed guys I would caution you to watch your oil pan level that it's not too high. I started out with a Novi 1200 oil fed and it started to make noise with <500 miles on it. I had it rebuilt and it came back good but then started doing the same thing in <500 miles. I talked with Vortech/Paxton support about it at length and sent them many pictures and videos and measurements. We never were able to definitively find the root cause but a theory was that the crank case oil level was at/near the same level as where the hole for the drain was tapped into the pan, blocking the drain at times causing oil to back up into the head unit and coke the bearings. I didn't see a place to tap any higher on the pan so I don't know what I would have done about it other than to keep a little less oil in the pan. It was easier to switch to the self lubricated and take the drain out of the equation.
Old Oct 20, 2008 | 10:45 AM
Mr.Big's Avatar
Mr.Big
Very informative write up... Thanks for taking the time...
Old Oct 20, 2008 | 03:06 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
But you left out my YSi!! 1600CFM, 1200hp
Old Oct 20, 2008 | 03:38 PM
aTX427
Guest
Posts: n/a
I never liked the idea of lubricating the head unit from the engine oil.
Old Oct 20, 2008 | 04:36 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Very good post! Thank you for the info
Old Oct 20, 2008 | 06:57 PM
7RED's Avatar
7RED
Thanks for the info...I didn't know
Old Oct 20, 2008 | 07:32 PM
sea six's Avatar
sea six
This is good information. Gives one something to think about or should I say even more to think about.
Old Oct 20, 2008 | 08:34 PM
MrDrezzUp's Avatar
MrDrezzUp
Thank you.
Old Oct 21, 2008 | 12:05 AM
Skunkworks's Avatar
Skunkworks
Originally Posted by 5 Liter Eater
Vortech=Paxton
Air Flow
Procharger:
P1 - 1200 CFM
D1 - 1400 CFM
F1A - 1650 CFM
Vortech:
S-Trim - 1000 CFM
SQ-Trim - 1000 CFM
T-Trim - 1200 CFM
Ysi - 1600 CFM
Paxton:
There is some debate about the supportable horsepower numbers, some believe they are artificially low, but it's safe to say that more is better, to a point. So on paper the advantage would seem to go to ATI but one would need to look at the compressor maps to see which would be better for a given application.
Procharger compressor maps - <not available at time of posting>
Gears
been saying it for years... Vortech tends to introduce better aero designs first. Only exception was the self contained gear box that was introduced under Paxton name.
Oh its actually Paxton = Vortech, as in Vortech technology is used in newer Paxtons not the other way around.
Mike
Old Oct 22, 2008 | 01:15 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
The Paxton and Vortech units are exactly the same inside.
The larger Paxtons (2000) are slightly different and equate to a JT Trim Vortech in airflow.
The YSI is the big boy and outflows the Paxtons.
I think that Procharger overstates their numbers slightly.
I generally make the same power with a T Trim as with a D1SC.
The rattling noise in the Procharger head unit is actually a "slinger " gear that rides on an independent shaft that slings oil up onto the drive gears.
Once there is a little load on the unit, the gear quits rattling.
The whining that is heard with the rattling is the straight cut drive gears.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Oct 22, 2008 | 01:36 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
You also forgot that the NOVI 2200 is the same as a JT-Trim.
There is no equivalent to the YSi-Trim for the NOVI...
There is no equivalent of the NOVI 2000 on the Vortech side. It's between the T and the Ysi
Old Oct 24, 2008 | 05:30 PM
Stage7's Avatar
Stage7
This should be a sticky in this section. Very helpful. Thank you.
Old Oct 24, 2008 | 08:43 PM
jxhunte's Avatar
jxhunte
Thanks for all the good info. I have been reading the FI section for some time and contemplating going FI at some point. The longer I wait the more I learn.
To Some Centri Info
