C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Automatic NPP Actuator for $25!
Old Jan 25, 2009 | 09:36 PM
  #41
EdwardETraylorIII's Avatar
EdwardETraylorIII
check valve might be a good idea. those diaphrams werent designed to see positive pressure
Nick,
You're probably right however I've had positive pressure on a couple of my C6Z's for many many thousands of miles and never had a problem. Have you ever seen a malfunction because of pressure?
Old Jan 25, 2009 | 09:54 PM
  #42
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Originally Posted by EdwardETraylorIII
Nick,
nope but i dont think that part(diaphram) is serviceable so.....just a couple of bucks for check valve so why not...
Old Jan 25, 2009 | 10:04 PM
  #43
EdwardETraylorIII
Very good point!!!
Old Jan 25, 2009 | 10:24 PM
  #44
NICK YOSKIN
St. Jude Donor '08
Very good point!!!
hey ed look at this site....they have almost everything
http://www.mcmaster.com/#about-check-valves/=bjug4
Old Jan 25, 2009 | 10:25 PM
  #45
EdwardETraylorIII
I've got the catalogs sitting right in front of me, bud.
Old Jan 25, 2009 | 10:34 PM
  #46
NICK YOSKIN
St. Jude Donor '08
Originally Posted by edwardetrayloriii
i've got the catalogs sitting right in front of me, bud.
lol!!!!
Old Jan 25, 2009 | 10:58 PM
  #47
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Zero issues with mine at 10PSI; those actuators are replaceable and cheap if you had to.
Most importantly, a check valve will prevent the system from working at all ...
Old Jan 26, 2009 | 09:57 AM
  #48
bearnest's Avatar
bearnest
isn't check valve to keep your crankcase from filling up under boost?
Old Jan 26, 2009 | 10:17 AM
  #49
PowerLabs's Avatar
PowerLabs
It is to prevent two way flow of a liquid or a gas. A&As FI kit adds one for that reason. Your car also has one on the brake booster so it is aways under vacuum. Adding one to the NPP actuator would make it either always closed or always open... Not very useful
Old Jan 29, 2009 | 12:07 AM
  #50
NICK YOSKIN
St. Jude Donor '08
cool.....gotta part # or a price...i need one!!
please explain why it wont work.....insurance saleman here not an engineer. just a dumby here
Old Jan 29, 2009 | 10:11 PM
  #51
PowerLabs's Avatar
PowerLabs
Well, think about it a little bit: The NPP Mufflers close when they see vacuum, and they open when they see no vacuum (atmospheric pressure or boost).
A check valve is a one way valve. So, if you put it towards the mufflers, it will allow boost through when you get on the gas, opening the mufflers, but then when you get off the gas, it will close; the mufflers will never see vacuum so they will never close.
Reverse the check valve and the reverse happens; it is open under idle and decel, keeping the muffler butterflies closed, but the second you get on the gas he check valve closes so the mufflers never see anything above vacuum and thus they never open.
Not sure where you can get those actuators... Gene Culey from GMPartswarehouse can help you out though.
Old Jan 29, 2009 | 10:28 PM
  #52
nwc6's Avatar
nwc6
Well, think about it a little bit: The NPP Mufflers open when they see vacuum, and they close when they see no vacuum (atmospheric pressure or boost).
Sam, you got it backward..Mufflers are open at startup..ie no vacuum, and close when vacuum is present. Thanks for the writeup and pictures..I'm plumbing mine up in the next couple of weeks..
