C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Highest Coolant Temps?
Old Jul 3, 2009 | 09:18 PM
NandoZ06's Avatar
NandoZ06
Originally Posted by Mr.Big
215* sitting in Texas 103* sweltering heat!!!
Exactly down here in Houston!Im seeing coolant temps between between 215-225
Old Jul 4, 2009 | 01:00 AM
vinnie12345's Avatar
vinnie12345
I live in Las Vegas 110 degrees, driving in traffic with the A/C on I see 237 to 241. Procharger P-1 stock radiator.
Old Jul 4, 2009 | 09:28 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Originally Posted by PAUZAO
GM, that is EXTREMELY high. I would definitely not be comfortable with anything above 220 degrees.
I agree - I am at 220 in stop and go traffic. I have the Dewitts radiator and JUST added the dual dans - we will see what happens.
My culprit is the Diamond forged cylinders I just added. I was well within 200-210 @ 600 RWHP via my Procharger D1SC and just the Dewitts.
I think I should add an external tranny cooler to take some pressure of the Dewitts combination radiator.
Old Jul 4, 2009 | 09:30 AM
RareSS9596's Avatar
RareSS9596
So this morning I took a ride at about 3:30 a.m. Outside air was about 65. Coolant temps while driving around town never went above 180! The other day with temps around 85 I saw coolant temps of 237 in stop and go traffic. I hope the DeWitts radiator and vented hood helps. I guess if I was doing it all over again I would do the radiator when I did the blower.
Old Jul 4, 2009 | 05:44 PM
Luweegy's Avatar
Luweegy
Make sure nothing is pushing the your inner cover down againt the ac condensor.It really slows airflow down.We had one last week that had popped the 2 plastic pins out of the front bumber support and laid it down on top of the ac condensor.We saw a 10 degree drop in temps after we fixed it.
Old Jul 6, 2009 | 04:34 PM
wwbill617's Avatar
wwbill617
Originally Posted by CPG1962
How new is your forged block? I just added Diamond Forged Cylinders and my SC car temp went from average 210 (after spirted driving) to 230. I have been told the break-in on forged cylinders is 5K miles . from a VERY trustworthy source. I am running Rotella break-in oil for the 1st 5K miles and the (thank God) switching back to Royal Purple. I should then see my temps drop back to close to normal levels.
Thanks CPG, Brand new. 625 miles. Yes I have the Diamond forged pistons and the builder did not seem too worried about the temps. Still on the break in oil. I will live with it and have just added Water Wetter to see if it helps any.
Bill
Old Jul 10, 2009 | 03:56 PM
coletrickle's Avatar
coletrickle
Default great thread that raises questions
Just got my A@A installed with stock radiator. THe shop said they were afraid to put the 160 stat in because I might not get enough heater in the winter??????? Havent heard this before- have any of you? When on the highway in 113 degrees I am running 203 but in traffic stop and go it went to 225 and a/c started cutting in/out. Am running purple ice already. How hot do we let things get before we worry, damage, or overheat??? The shop told me to let them know how things went, but at what point do we change?
THanks
Old Jul 10, 2009 | 04:10 PM
wwbill617's Avatar
wwbill617
THanks
My shop said to let them know if it gets over 240. I put some water wetter in and now it only gets above 230 after full throttle pulls in a few gears... Most of the time while in traffic it stays between 218-225. that was with the outside air temp reading 108. I think once I get the engine broken in good, and I can go synthetic on the oil it will drop further.
Bill
Old Jul 10, 2009 | 04:38 PM
Motorhead-47's Avatar
Motorhead-47
THanks
Unless you are up in the mountains of New Mexico I'm really surprised they didn't automatically put the 160 in and rework the fan settings accordingly. In the New Mexico desert it seems like a no-brainer decision to me. You need those fan settings turned up to a more aggressive profile to prevent the heat soak in traffic and you want the thermostat to begin opening earlier. It's going to be a lot harder job now that the supercharger is setting squarely in front of the thermostat housing.
Sample F/I fan compared to stock profiles are below. See how much more aggressive the fan speeds are in the second chart? This example is very aggressive and some might not like the fan noise at 90% so early but this is entirely tweak-able. The real takeaway is that the stock settings don't even hit 50% fan until >214 degrees!
Old Jul 10, 2009 | 05:43 PM
coletrickle
I don't know what the fan speeds were set at, but i do know they kick on at 200 but i couldn't tell you at what percentage. I will ask them. I dont live in the desert, but at 6000ft. we have 4 real seasons, 100 is rare in summer but happens, winter is to 0 but I dont take her out below 30 unless I get caught out. Does any of this make a difference?
Old Jul 10, 2009 | 05:55 PM
Motorhead-47
I based my reply on your comment above...assumed you were low desert. If you are driving in 113 degree weather regularly I'd change the t-stat and fan settings.
Old Jul 10, 2009 | 06:25 PM
coletrickle
not regularly, was visiting tucson. How hot is too hot? when does overheat occurr? THanks
Old Jul 10, 2009 | 06:30 PM
  #33
Motorhead-47
I feel your pain. I lived in Tucson for 7 years. That heat can be brutal in the summer and in traffic with the a/c working hard and the added thermal impact of the intercooler and s/c unit you were really pushing things hard. I'd consider that a rare extreme unless you regularly visit Tucson. If you do, consider at least having the fan speeds modified to be more aggressive. The a/c was cutting out because you were exceeding it's high pressure limits due to the high ambient air temp and the condenser's inability to keep the a/c system temps in check. It shuts down the ac compressor to keep things from going high order (damaging the compressor or hoses or fitting/o-rings).
I once had an air conditioner hose blow in Tucson while sitting at the drive-thru window at McDonald's..scared the crap out of me and the kid who had his head hanging out the window with my Big Mac!
Old Jul 10, 2009 | 06:43 PM
  #34
IPS Motorsports's Avatar
IPS Motorsports
What is the set up on the car? Blower, TT, N20? This is vary some decision, on how to properlly cool the system, mainly on the placement of the intercoolers, and seperate oil and or trans coolers that may be installed.
What thermostat?
When do the fans come on?
Does the temperature seem to want to still climb further after 239?
Is the system bleed properlly?
AC on?
What are the oil temps during this period?
I could ask a lot more questions, but don't just assume a bigger radiator is your only fix, there may be multiple things that are causing the extra heat in the cooling system. If you go into more detail , that will allow me an other members to give better more accurate feedback. Your always welcome to email myself as well, ill reply via blackberry if I am not in the shop.
Good luck
-Brandon
Old Jul 10, 2009 | 08:11 PM
  #35
coletrickle
What thermostat?
AC on?
Good luck
-Brandon
setup is 07 z51 mn6 stock radiator with purple ice, v2si trim A@A LT jet hot headers, 3"Xpipe, high flow cats, exhaust. T-stat as I noted earlier is stock--they didnt want to install the 160 stat because they thought i would lose my heater in winter. Fans come on at 200. temp has never been over 225--I got worried and turned off a/c and luckily hit highway soon after. oil temps always 220 never over even on high pulls.
Hope this helps. thanks.
Old Jul 10, 2009 | 10:06 PM
  #36
bigterpsfan's Avatar
bigterpsfan
If I am stopped for several minutes my temps reach as high as 220, but quickly drop back to high 180s low 190s at cruise.
Old Jul 11, 2009 | 05:17 PM
  #37
coletrickle
ttt
this thread isn't done!!!
To Highest Coolant Temps?
Old Jul 13, 2009 | 02:01 AM
  #38
vvette_c6's Avatar
vvette_c6
i am getting 221
to 230 while driving between houses and traffic lights
with crousing i get 197
using thermostat 160
but temp get in my country up to 122 !!! 50 Celisius
i am working to Fit electric water pump in in my car ,, + biggers fans with higher CFM
or getting Extra Fan and fit it in my car ,, with external Switch
Old Jul 13, 2009 | 08:10 AM
  #39
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I rarely crack 200 even in 100'+ heat and stop and go traffic. I have a 160' t-stat and I do also have the 2 bar HP Tuners OS which extends the fan table down to 163' and I have mine set to come on full bore (90%) at 180'.
BTW, if you put anything greater than 24% in the 192 column of the stock fan table the fans stay on all the time.
Old Jul 13, 2009 | 03:19 PM
  #40
IPS Motorsports
Sounds like honestly its just a thermostat issue, I would really push for the 160 degree thermostat. And I would be willing to bet you loose no heat either, just let you car warm up properly, which is important in the winter as well in order to get the oil to proper visciosity properties.
I wonder if the intercooler is'nt trapping heat in front of the radiator and ac condenser as well, causing the heat to climb when the A/C is on.
-Brandon
