C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Highest Coolant Temps?
Old Jul 13, 2009 | 10:13 PM
  #41
Bone Daddy's Avatar
Bone Daddy
Member: Jr Geezer's Club
Does it really matter what radiator you have when there is a big honkin air-to-air or air-to-water intercooler sitting in front of your main heat exchanger blocking the air flow?
I am aware of the "gap" approach but sheeesh how much cooling can really be had by that?
I am having my TVS2300 installed this week at 21st Century Muscle Cars in Dallas and they are not even recommending an aftermarket radiator. (???)
Bone
Old Jul 13, 2009 | 11:17 PM
  #42
coletrickle's Avatar
coletrickle
Originally Posted by IPS Motorsports
Sounds like honestly its just a thermostat issue, I would really push for the 160 degree thermostat. And I would be willing to bet you loose no heat either, just let you car warm up properly, which is important in the winter as well in order to get the oil to proper visciosity properties.
I wonder if the intercooler is'nt trapping heat in front of the radiator and ac condenser as well, causing the heat to climb when the A/C is on.
-Brandon
thanks, I am going to el paso this weekend. should be over 100 there, we'll see what she does, but if she still climbs, i'll push for the 160 stat and go from there. They had mentioned putting another bottle of purple ice in and that the first one takes time to work properly. Install looks ok for the intercooler, but how do you avoid the air trap?
Old Jul 14, 2009 | 04:51 PM
  #43
Ragtop 99's Avatar
Ragtop 99
Originally Posted by coletrickle
I dont live in the desert, but at 6000ft. we have 4 real seasons, 100 is rare in summer but happens, winter is to 0 but I dont take her out below 30 unless I get caught out. Does any of this make a difference?
No.
Put in the 160 t-stat. The 160 does not cause the car to lose heat. I've driven my car on my mornings when it has dropped into the 20s and warms up to 160 just fine, eventually settling in about 180 on open road. The only downside is in the winter my oil temps rarely get above 180 on a 30 degree day (I'm NA). I going back to stock fan settings next winter as that will allow the oil temps to climb in stop and go traffic.
Old Jul 14, 2009 | 05:00 PM
  #44
TMRoc's Avatar
TMRoc
Originally Posted by Ragtop 99
No.
What is a good oil temp for a NA car at lets say 50 degree days and 100 degree days ?
Old Jul 15, 2009 | 01:22 PM
  #45
Ragtop 99's Avatar
Ragtop 99
I like the oil to get up to 200*. That seems to be a temp where others have suggested the motor is good thermally and it is generally hot enough to boil off moisture.
Old Jul 19, 2009 | 08:55 AM
  #46
vvette_c6's Avatar
vvette_c6
Default procharger and heat how to kill
http://forums.corvetteforum.com/c6-f...t-monster.html
Old Jul 24, 2009 | 11:48 AM
  #47
Slvr08Z51's Avatar
Slvr08Z51
I have an 08 W/P1sc 9lbs w/meth 640rwhp.. It was getting up to 230 in 106 traffic here in TX, made me a little nervous.. I drained all the coolant and put in a ratio fo 85% distilled water, 15% coolant and a bottle of red line water wetter.. It has dropped by 15-20.. I rarely see 220.. I will eventually add the dewitts, but this was a cheap and easy fix for now!
Old Jul 26, 2009 | 11:35 AM
  #48
BADZ's Avatar
BADZ
Just installed the Dewitts radiator and still seeing the 220-230 temps...Normal driving (stop and go traffic)
I was seeing the same temps with the stock radiator.
I'm running the 160 stat that RR installed with the ECS kit.
I will find out if my fans need to be re-set differently.
Old Jul 26, 2009 | 03:17 PM
  #49
wooden's Avatar
wooden
I put the dewitts in and did not see any drop in temps.
Old Jul 26, 2009 | 03:45 PM
  #50
mdk's Avatar
mdk
240 coolant temp after 20 min on track at or near full throttle, oil temps near 250 with dewitts with oil cooler. stock 260 coolant 280 oil.
Old Aug 7, 2009 | 07:32 PM
  #51
Dicecal's Avatar
Dicecal
I did not see any lower temps with the Dewitts in stop and go street driving either. Did seem to keep things cooler on the track though.
Old Sep 6, 2009 | 03:30 AM
  #52
bomariam1's Avatar
bomariam1
with dual fans or without?
Old Sep 6, 2009 | 07:44 AM
  #53
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default LOOK at this thread - It may help!!!!!!
http://forums.corvetteforum.com/c6-f...ns-cooler.html
Old Sep 7, 2009 | 09:51 AM
  #54
maxgee's Avatar
maxgee
Man, those are some high numbers. I don't have a vette, but I do have LS2 on boost and I'm here in hot south Florida and I'm usually around 199 after some hard runs. In traffic 185 to 190.
