C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Anybody else having an oiling problem like me?
Old Aug 31, 2009 | 01:18 AM
Street gear's Avatar
Street gear
Default Anybody else having an oiling problem like me?
I have an A&A SI-V3 supercharger. I put my car on the hoist yesterday and found a lot of oil under the car. A closer inspection seems to have the oil coming from the air cleaner. It appears the oil is being sucked into the air cleaner and then blown everywhere else. What do I have to do to fix the problem? Do I need an oil catch can?
See:
The above picture is hard to see but the condensers for the air conditioner is literally plugged with oil and dirt.
Old Aug 31, 2009 | 01:19 PM
EuroVette07's Avatar
EuroVette07
If you have an external oil cooler in the front check the lines.
Old Aug 31, 2009 | 01:25 PM
Street gear
On the Z06 the oil cooler is part of the radiator. I have checked all those lines it's totally dry.
Old Aug 31, 2009 | 01:33 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I suspect this is blowby, if it is ending up on the air cleaner through the oil cap vent line. My car doesn't do this because I am running both vent lines to ground. A catch can would accomplish the same thing.
Old Aug 31, 2009 | 01:47 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Take the plastic air bridge off as well and make sure the impeller seal is not leaking.
Old Aug 31, 2009 | 01:51 PM
Street gear
Steve what plastic air bridge are you talking about? Do you have any pics? I was thinking about installing a catch can between the line that runs to the air cleaner up front. That was the line that went to the accordion from the factory.
Steve if you look at the last picture that I posted you can see the oil on the air conditioner condenser.
Old Aug 31, 2009 | 02:04 PM
Former Vendor
The plastic piece that attaches to the filter. Take the hose off the supercharger and look inside at the impellers... see any oil?
Old Aug 31, 2009 | 03:43 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I would check the intake like Steve said. It will show whether it's coming out the front seal or if it's blow by coming from the line from the valve cover oil cap.
I originally had an engine oil fed Paxton. It leaked out the front seal and was sent back to Vortech for rebuilds twice. Never definitively figured out what the problem was as I upgraded to the self contained unit and the problem was solved. I suspect that it was not draining properly even though the drain line looked good (no uphill bends) so oil would back up in the head unit and have nowhere else to go bout out the front seal.
Your pics don't look like what mine did though.
Old Aug 31, 2009 | 04:40 PM
Former Vendor
He called in and I think we figured it out! Don't overfill your engine oil!
Old Aug 31, 2009 | 07:31 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Nothing like some nice foaming oil on a blown LS engine.
Old Aug 31, 2009 | 07:54 PM
Keith N's Avatar
Keith N
Hiigh Oil Level - The same thing happened to my C6 with a smaller oil drip. Thanks for the info.
Old Sep 1, 2009 | 12:33 AM
pamperedcar1's Avatar
pamperedcar1
Default oil
oil level, oil level, oil level tooo high oil being sucked out through breather tube.
Old Sep 1, 2009 | 09:33 PM
coletrickle's Avatar
coletrickle
I thought the V3 si was self contained? isnt the v2 si the oil fed one?
Old Sep 2, 2009 | 11:20 AM
Former Vendor
That is correct... but we are talking about engine oil...
Old Sep 3, 2009 | 10:25 PM
coletrickle
sorry, was referring to the original post as he says he has a V3, but then the conversation moves to having too much engine oil. If it's a v3 then what would that matter?????
To Anybody else having an oiling problem like me?
