C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Edelbrock E-Force
Old Nov 3, 2009 | 06:33 PM
Dan Wendling's Avatar
Dan Wendling
Default Edelbrock E-Force
Anybody have more details then the attached on the Edelbrock E-Force FI system?
When will it be available?
Do they have authorized installers?
Does it come with its own ECM, or can you reflash the existing?
Does it include new injectors or use the existing?
What are they doing for a fuel pump in the 599 hp version?
Must be someone at SEMA that has answers!!!
File Type: pdf
Old Nov 3, 2009 | 09:35 PM
stkjock's Avatar
stkjock
my .02... watch out for their boost claims relative to power made. when they rolled out the kits for the new 3V mustangs their claims turnout to be a "stretch" from what the kits showed on the dyno.
they do make good power on the 4.6L 3V motor
Old Nov 5, 2009 | 05:54 AM
MarkRx's Avatar
MarkRx
just watched an 8 min video on youtube, looks interesting.
Old Nov 5, 2009 | 09:52 PM
JerriVette's Avatar
JerriVette
The company is only claiming 114 hp increase over the stock LS3. Thats enough power that the stock drivetrain should hold up just fine.
I realize many people want more power etc...but I'd take 550 hp and stock like reliability any day of the week..
the warranty that is optional is also a key feature to many corvette owners....Not sure what the optional warranty costs...or what it entails...but 5 years/100k mile warranty sure sounds tempting...(depending on what it costs and what it cover)
599 flywheel hp with fuel pump mod...isn't too shabby either..
Stock clutch should hold up fine with those power levels too..
Look foward to more info as it becomes available..
Old Nov 10, 2009 | 12:33 AM
bosco 08's Avatar
bosco 08
i called Edelbrock today about the Corvette kits no prices yet but he thought it should be comparable to the Mustang kit. he also said the kits will not be available until the first of the year and yes there is a warranty available.
i can't wait.
Old Dec 24, 2009 | 04:37 AM
Telepierre's Avatar
Telepierre
So, going back to the original questions (fuel pump). What do you think would happen if I opt for the 599hp kit without actually installing the Edel. fuel pump? Let's say I am very conservative with the throttle and I just want the all thing just once in while?
Old Dec 24, 2009 | 02:18 PM
bosco 08's Avatar
bosco 08
your car will not get enough fuel with the 599hp kit hence the high volume pump required. call Edelbrock and ask them if you can use this, they work great.
http://www.kennebell.net/accessories...boostapump.htm
Old Dec 24, 2009 | 04:54 PM
knkali's Avatar
knkali
http://www.motorator.com/videos/1111
Old Dec 24, 2009 | 05:05 PM
Motorhead-47's Avatar
Motorhead-47
I believe I heard him (Vic Edelbrock) say "Z06 Fuel Pump" in the video. Z06 fuel pump has a higher output than LS3 pump?
Old Dec 25, 2009 | 06:24 AM
Telepierre's Avatar
Telepierre
Thank you - good points and great to see there may be a less costly and intrusive work around. I'll follow up with that and post accordingly.
Old Dec 25, 2009 | 01:30 PM
71'AirStrike's Avatar
71'AirStrike
yes.
I was searching the camaro forums and they too are excited about the E-Force S/C.
A semi Inside person was at Sema (Nov 09') and played 20 questions with Them about the E-Force.
Here was the conscesus
-The standard c6 intank fuel pump wil make 500 HP (flywheel) and thats it. Walbro (a supplier of the fuel pumps to GM?) stated that if you add "an increased voltage to the Standard C6 Fuel pump, it will dramatically shorten the life span"
-The Z06 Fuel pump pumps more gas AND per Walbro " it can take 18V all day long and be just fine"..can anyone say Kenny Bell BAP?
-The camaro intank pump will be able to handel the 550 HP with no problem. They implied that it can handel much, much more.
-The 550HP E-force does comes with a GM z06 fuel pump, but per Elderbrock "It will take 2 days just to install the pump itself" ..as they are implying the pump will require dropping the tranny, and tanks.
Old Dec 25, 2009 | 02:33 PM
z06801's Avatar
z06801
wouldn't any system require the same fuel upgrades to make the same power?
Old Dec 26, 2009 | 04:47 AM
Telepierre's Avatar
Telepierre
The more I read this thread the more I am inclined to opt for the boost-a-pump option based on the following:
1. I do not use my C6 as a daily driver but as a weekend driver.
2. Most of my driving is leausure driving and German HGW as well. We are talking constant 1500-2500 rpm stuff.
3. I need the power for those privileged occasions of Close Encounters of the Third Kind with M3s/M5s/Porsches/Ferraris :-) If I am lucky once a weekend...
4. I buy the 1591 and use the pump as a spare just in case..
I have found a schematic on boost-a-pump but it does not illustrate were the components and work is done? Is it all done under the hood/trunck? I'll look but any help in regard is appreciated.
Old Dec 26, 2009 | 02:25 PM
Telepierre's Avatar
Telepierre
Never mind the question. Found plenty of info in this forum:
http://forums.corvetteforum.com/c6-f...post1560557754
Old Feb 2, 2010 | 12:51 PM
Telepierre's Avatar
Telepierre
Ok then:
http://www.edelbrock.com/automotive_...gers/corvette/
Available 5th FEB!!
Old Feb 3, 2010 | 07:39 AM
TMRoc's Avatar
TMRoc
I heard they will start shipping on 01/27/10? Anyone got one on the way?
Old Feb 3, 2010 | 02:55 PM
Telepierre's Avatar
Telepierre
Talked to SUMMIT who talked to Edelbrock:
still in engineering and development. They have not even produced a single one yet.
Couple more months...outch!
To Edelbrock E-Force
Old Feb 3, 2010 | 04:46 PM
j_digi454's Avatar
j_digi454
The attached post will answer most of you questions.
http://forums.corvetteforum.com/c6-f...er-dealer.html
Old Feb 4, 2010 | 01:34 PM
Telepierre's Avatar
Telepierre
Grazie! Danke! Thank you!
I am trying to understand if Howard & co are building a kit on top of the Edelbrock one or they take cars in to mount the Edel. E-force and do their magic?
Or in other words, do they ship an enhanced kit?
Old Feb 4, 2010 | 03:26 PM
j_digi454's Avatar
j_digi454
It sounds like they will provide and mount both. I don't know if they would provide the enhanced version they're working on as a kit. Maybe they can answer the question for all of us.
