Ordering my engine tonight!
I will keep my Si-Trim supercharger and pulley it down to 3.4", maxing out the blower somewhere in the 700WHP range.
I will swap out my fuel pump for a C6 Z06 pump and keep the BAP.
I will add a Methanol Injection kit
Engine setup as follows:
My stock LS2 365 cu. in. Balanced, blue printed and assembled with stock GM crank w/indexed & trued journals,
Callies 6.125" H beam rods rods, Wiseco 4.005" forged FI pistons w/tool steel wrist pins & anti friction coating on skirts
Total Seal stainless chrom rings .047 .047 3mm rings, Clevite MS2199 H main bearings, Clevite CB663 H rod bearings, Dura Bond cam bearings, ARP main studs, all oil galley plugs & dowel pins.
Custom Blower Cam, cam retainer plate
Timing chain Roll master double roller timing set w/ torington bearing & nitrided gears.
Melling 10295 high pressure, coated oil pump, ported
LS 2nd design ARP Pro Series 12pt. head stud kit for late model blocks
LS7 GM LS7 hydraulic roller lifters
Lifter Tray & Bolts LS1 Lifter Tray & Bolts
GM MLS head gaskets
I will re-use my heads; they will be lapped, resurfaced and re-assembled with:
Dual valve springs w/titanium retainers, amchined locks & locators, Viton valve seals
Manley 7.4 Manley 1 piece chromoly push rods 7.400" x 5/16 x .080" wall
I am requesting 10:1 compression. I expect that the blower cam will drop my boost down by about 1.5-2PSI, and pullying the blower down from 48000RPM at redline to 54000RPM at redline will raise boost by about 4PSI. I should be seeing 12-13PSI max with this setup which I expect to be fine for 93 octane + meth injection on a forged motor.
That's it. It will go back in the car with an RPS twin disk carbon-carbon clutch. I decided not to stroke, upgrade the blower, or add aftermarket heads on the interest of keeping everything (including clutch, meth kit, and other misc. stuff) under 7 thousand dollars since I still plan on selling the car and starting a new project in about a year and a half or so. I also think if I went much further than that I'd need a widebody kit, wider wheels and wider tires to get traction, and the engine would need a fuel system, an 8-Rib drive, and bigger injectors, and then the build would easily run into double my budget.
Comments / Suggestions?
BJK
If money's an issue, just put pistons in the stock block (honed 4.005), put studs in it and leave the rods and crank alone.
Just my opinion, and others will disagree, but I think that's money better spent.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
...just get the 8 Rib like Andy says and trade in the V2si for a T trim and make a solid 750 with it working less. Im sure Andy could give you a great trade in on the Si
Its bad isnt it.....like a disease.....
On a side note, threads like this make me glad I started with the T-trim and 8-rib 3.8" pulley, so I've got some room to grow into the equipment. Of course my tranny would probably explode before I got to 700whp
Andy, you know I respect your opinion, but the 8-Rib is another thousand dollars on a 7K build... If you can give me a better deal I'll swing it, but with the clutch, engine mounts (found out one of my mounts broke) and other stuff I really am trying to keep it under control here...
Re: Car. Today I bought a (rather) used BMW 328Is today. It is horrible: it is automatic and slow, but it'll get me around in winter untill the 'Vette is all done.
best of luck on your new build!!
I am getting a Melling 10295 high pressure, coated oil pump that is also being ported. Is that good enough you think?
I didn't know you could run a 6 rib on an 8-Rib pulley... That's good to know! I will at the very least go that route then since I was planning on replacing my harmonic dampner.
