C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS7 Block Limits
Old Dec 28, 2009 | 10:03 PM
McMung's Avatar
McMung
Default LS7 Block Limits
Assuming the right rotating assy and valvetrain bits are used, what is the LS7 BLOCK's limits (assume stock 4.125 bore) in terms of FI boost/power levels?
Old Dec 28, 2009 | 11:06 PM
Zteve's Avatar
Zteve
Depends on the use. A dyno queen will put up with more power than someone who actually uses the car hard. IMO, there's probably a 200-300rwhp difference between what it will take on an occassional basis vs what it will take if you race it regularly.
Old Dec 28, 2009 | 11:44 PM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
Stock sleeves are inconsistent at best. If money permits I would prefer not to use them. Sure is a lot cheaper to do it right once, than have to fix it later.
Old Dec 29, 2009 | 09:51 AM
HotRod68Camaro's Avatar
HotRod68Camaro
Taylor, are you suggesting resleeving or just a different block?
Old Dec 29, 2009 | 11:10 AM
Former Vendor
Very impressed with the RHS block for the cost. We have a few builds going together with the RHS standard deck blocks and will be selling the LS7 blocks. Before the RHS block, sleeving the LS7 made a lot of sense.
Rough cost is $3000 for sleeves, machine work, install on LS7 block.
OR
$4500 for RHS block which has 6 bolt head provisions, billet mains, good sleeves, more rigid design, etc.
Seems like a no brainer to me. Not to mention the LS7 short blocks if still in good shape bring about $3500.
Old Dec 29, 2009 | 02:19 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
We have made 965rwhp and been 8.81 with our stock ls7 block. I agree with taylor though. If money allows resleeve it. I have used a few from ERL and they work good. Let me know if you need help with anything.
Old Dec 29, 2009 | 06:38 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
OR
well said.
Old Dec 30, 2009 | 01:58 AM
McMung's Avatar
McMung
Just had a look on the RHS website, looks pretty nice. Aside from the obvious price disparity, how would that compare to DART's billet alum block for a 427ci FI application? power handling, oiling features, ... Just curious.
What kind of setups are you using RHS' blocks for?
Old Dec 30, 2009 | 11:15 AM
Former Vendor
RHS block was designed for race applications.
Dart block was designed for bling applications or if you just have too much money.
Old Dec 30, 2009 | 11:42 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Like stated above, the LS7 block is not the best foundation for boost. The sleeve composition was not designed to withstand the cylinder pressures associated with boost. Period. Re-sleeving the LS7 block with Darton, high nickel sleeves is an effective upgrade but may not be the best value considering the RHS block availability.
The RHS block offers premium sleeves, steel caps & main studs, priority main oiling, 6-bolt head mounting, and a host of other durability improvements over the LS7.
Base cost of the RHS is ~$4,500 and final blueprinting operations will be far less than if one used an LS7. Typically the block needs little more than torque-plate honing to finish bore size.
Assuming one already owns a suitable LS7 core, a comparable prepped LS7 (Darton Sleeved & blueprinted) will run ~$2900. At this point one would be wiser and money ahead (IMHO) to sell the LS7 core and buy the RHS.
Old Dec 30, 2009 | 12:41 PM
BADZ's Avatar
BADZ
Again, this could go on forever as plenty of guy´s including myself are making great power with a low comp stock block 427. fyi.
It is although a nice upgrade but how many failures have been recorded using the stock ls7 for boosted app??? How much boost???
Old Dec 30, 2009 | 01:45 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
There have been little failures, but one failure is all it takes for me to investigate.
We made over 1000 rwhp on a factory stock sleeved/LS7 block, and 6 texas mile runs at 900 rwhp+ with no issues. That engine is still in service today, and prior to that, it was in a 800 rwhp nitrous Z....
I will say the tune-up has more of an impact than 20 psi of increased cylinder pressure. The limits come from making a mistake. Read up on Formula one engines.... detonation and the streeses on the parts that come from the mistake. 20 psi under controlled combustion is a negligible rise in stress, but when uncontrolled combustion happens, thats when we break parts.
Old Dec 30, 2009 | 04:26 PM
pianoprodigy's Avatar
pianoprodigy
St. Jude Donor '12
Seems the MTI TVS cars are holding up pretty well pushing mid 700s at the tire, no?
Old Dec 30, 2009 | 06:23 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
What about the LS9/ZR1 block?
Old Dec 30, 2009 | 06:52 PM
Former Vendor
Only available as a complete crate engine. There is no ETA or availability on the LS9 bare block according to my GM rep. New bare LS3 block is available as we have built several engines with these and do have some of the newer windage work around the mains and such but is still wet sump design and does not use the 11mm head bolt.
Few real pics of the RHS for you guys. One really cool thing about the RHS is that I *think* we will be able to remove the lifters withOUT removing the cylinder heads since these windows are so large. I'll try later and confirm this.
Old Dec 30, 2009 | 07:05 PM
bullitt4110's Avatar
bullitt4110
That would be pretty cool! That is one nice looking block!
Old Jan 1, 2010 | 10:03 AM
Gannet's Avatar
Gannet
St. Jude Donor '06
Will the RHS block work in an LS7 dry sump application? What do you do for a cam chain?
Is there anything else "special" that has to be done when building these? Special gaskets, fasteners, etc?
Any mods necessary to use one in a C6Z, or is it a straight bolt-in with all factory mounts, accessories, etc?
To LS7 Block Limits
Old Jan 1, 2010 | 07:12 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
You of course know that if you are boosting 20PSI, the cylinder pressure is only 20PSI higher prior to ignition... At 20PSI your air/fuel mixture is about 125% denser and will release more than twice as much energy as it would if the engine was N/A... The post ignition combustion pressure is much greater than those initial 20PSI
Old Jan 1, 2010 | 08:19 PM
Former Vendor
Oh yes, well aware of that small part of the equation.
Old Jan 2, 2010 | 03:36 PM
0C_Williams@RPM
Former Vendor
N/A = 1145 PSI Cylinder Pressure
20 lbs boost = 1829 PSI Cylinder Pressure
