C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-force supercharger
Old Mar 17, 2010 | 08:51 AM
  #101
Motorhead-47's Avatar
Motorhead-47
RPM installed a 1591 last week... http://forums.corvetteforum.com/c6-f...ok-inside.html
Old Mar 18, 2010 | 01:42 PM
  #102
Team STILLEN's Avatar
0Team STILLEN
Former Vendor
For any CorvetteForum member interested in the new Corvette E-Force Systems check out....
http://forums.corvetteforum.com/c6-f...promotion.html
STILLEN has been in business for over 25 years so you know you will get the best customer service and the best technical knowledge available. As an authorized Edelbrock E-Force installer, we are also offering the extended warranty from Edelbrock at an additional charge. STILLEN is also a warehouse distributor for many of the most popular Corvette performance parts manufacturers:
KW Suspension
PFADT Racing
ACT Clutch
HRE Wheels
Penske Shocks
AP Racing Brakes
Magnuson Superchargers
RK Sport
Kooks Custom Headers
Edelbrock E-Force
Old Mar 18, 2010 | 02:45 PM
  #103
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Just started a 1590 install this morning... stay tuned
Old Mar 19, 2010 | 02:31 PM
  #104
Telepierre's Avatar
Telepierre
early last week i called Corvettes of Houston and they said they had one of each model 1590 and 1591 sitting on the floor ready to ship.
Thank you Bosco 08. I am trying to find a east coast/Central vendor. Houston Corvette sounds great. I'll give them a call.
Old Apr 10, 2010 | 07:00 AM
  #105
Telepierre's Avatar
Telepierre
Got few of E-forces in the US now...any 0-60 1/4 mile numbers?
Old Feb 15, 2011 | 08:20 PM
  #106
gmancuso's Avatar
gmancuso
Default E-Force install problem
I had the 599 HP version installed into a stock 2009 LS3 coupe and getting error code C0561 Invalid Service Data Received (service traction control)
under hard acceleration. The service engine light is coming on. There are 3 cylinders coming up with misfire codes but the car is not misfiring under extreme acceleration. The car performs fine and runs fine other than these codes showing up. Does anyone have any idea what this could be. I think it has something to do with the tune
When I turn the car off and back on everything resets with no error codes.
Old Feb 16, 2011 | 01:22 AM
  #107
Telepierre's Avatar
Telepierre
Do not have the ultimate solution for the misfire issue but 6000 miles ago as soon as I had my 599 kit (w/BAP) installed I experienced the misfire code and of course the traction control engagement light. I gather from other postings and Motorhead-47 that the traction control light is a normal occurence under heavy acceleration. I see it as a nice torque problem to have :-) But seriously I believe that is as natural as the seat belt light /message coming on when the seat belt is not buckled.
As for the misfire code it seemed to show up also under both normal and heavy acceleration at the 4000 rpm mark but at one random cilinder at the time with a preference for the 8th passenger side.
Tuner went by trial method and twicked the tuning and replaced sparks and switched coils with no apparent improvement.
After 6000 miles the misfire issue has diminished dramatically and unlike the past were it needed a reset now it temporarily shows up and clears itself out. Rare, kind of annoying, but IMHO the more I drive the more it goes away.
Please check/search other related posts on this forum. I'd love to get the ultimate fix myself.
Old Feb 16, 2011 | 06:49 AM
  #108
gmancuso's Avatar
gmancuso
Default Does your service engine light come on and stay on?
Thanks for the information. My yellow service engine light comes on and stays on. The traction controll error is an actual fault and not a warning of the rear wheels going faster than the front. I believe this might have to do with a sensor in the transmission picking up too much torque from what someone else has told me. They had to get a custom patch to fix this torque issue.
Greg
Old Feb 16, 2011 | 11:22 AM
  #109
yonson's Avatar
yonson
Are you using the canned Edelbrock tune? What tune version do you have? If you are getting P030X codes I would double check all of the injector/coil/plug connections to make sure everything is connected securely I've seen them not securely connected and cause misfires. Have the plugs been changed or regapped?
Old Feb 16, 2011 | 11:55 AM
  #110
gmancuso's Avatar
gmancuso
My installer is using the latest tune and I personally checked it off the Edelbrock web site against what the handheld was reading. My installer has already checked for loose connection and is checking the plugs and gaps via instructions from Chris at Edelbrock (tuner). He is also checking fuel pressures under load in case the fuel pump wasn't installed correctly. The coils are being swapped to determine if any of the misfired cylinders change.
Thanks,
Greg
Old Feb 16, 2011 | 12:11 PM
  #111
yonson's Avatar
yonson
Auto or Manual?
Old Feb 16, 2011 | 02:32 PM
  #112
gmancuso's Avatar
gmancuso
Default The car has an auto transmission.
