C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
It is coming...
Old Feb 20, 2010 | 10:14 AM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Originally Posted by PowerLabs
You better believe it! This thing is going to FTD in autocross at Winged Warrior! And by FTD I mean DNF every run because it gets no traction before 80MPH Then it will get slaughtered by all the trailer queens on slicks at the drag strip... But in the end I will drive it back 1000 miles to NJ, and life will be great
Who Needs Traction??
Old Feb 20, 2010 | 02:17 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
What is this "traction" you speak of?
<=== I'm in the lab with the engine hovering above the engine bay right now!
Old Feb 20, 2010 | 04:24 PM
MachineWorks's Avatar
MachineWorks
You will still have it, you just need to learn how to drive
Old Feb 21, 2010 | 12:18 AM
PowerLabs's Avatar
PowerLabs
Got the engine in, thanks to Roberto (Stage7) coming over and giving me a hand. Thanks!
Pulling it out of the car was easy. Getting it back in... Not so much!
6 Hours later:
Lining up the transmission input shaft with the clutch is very difficult, I am convinced if I do this again I'm going to drop the engine out the bottom along with the rest of the drivetrain.
Now the easy part
Old Feb 21, 2010 | 12:53 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Enjoy!!
Old Feb 21, 2010 | 06:38 AM
Res1cue's Avatar
Res1cue
6 Hours later:
Now the easy part
Only thing missing is that 3.3L whipple up top.
Old Feb 21, 2010 | 09:42 AM
wallyj's Avatar
wallyj
Default You are on the downhill slide now
I would have never thought it would be so tough to line up the input shaft. It's usually the unexpected things that waste the most time for me. I know I spent a good 4 hours trying to shoehorn an LT1 into an 87.
I just kept taking more and more things off the car and motor until it went. I thought it was going to be a 20 minute job...
Just a lot of wrench turning left now. Hopefully everything will fall into place without too much trouble.
Can't wait to see how it turns out.
Old Feb 21, 2010 | 09:59 AM
atomicC6's Avatar
atomicC6
Nice build. What clutch is that exactly ( street twin carbon, street twin carbon lite, billet carbon twin ( bc2). I'm about to get a clutch and was wondering what your clutch is rwtq rated for. Thanks and good luck with your install.
Old Feb 21, 2010 | 11:18 AM
Mr.Big's Avatar
Mr.Big
Originally Posted by Res1cue
Only thing missing is that YSI up top.
Fixed!
Old Feb 21, 2010 | 12:35 PM
Stage7's Avatar
Stage7
No problem Sam, keep the pics coming.
Old Feb 21, 2010 | 01:12 PM
PowerLabs's Avatar
PowerLabs
That is the RPS Street Twin Carbon; it is rated at 800RWHP (don't ask me why a CLUTCH is rated in HP, but that's the manufacturer spec )and weights 40lbs (16lbs lighter than stock
Old Feb 21, 2010 | 02:05 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Next time I'm in Carolina, I want a ride. Think that thing might make it to the Dragon this summer?
Old Feb 21, 2010 | 02:08 PM
  #33
techvette's Avatar
techvette
Looking good, Sam...
Old Feb 28, 2010 | 09:16 PM
  #34
PowerLabs's Avatar
PowerLabs
Default Update!
Got the steering rack back in (MAJOR PITA, second worse thing about the whole job so far), the ABS module and bracket, the front swaybar, all wires, grounds, plugs, sensors, my PFADT Silicone hoses (they are nice!), radiator fan, etc...
It is basically done except for the headers, intake manifold and supercharger! I'm going to install the headers as well as my Meth injection kit and a permanent wideband next week, then wait for A&A to send me my passenger side feed intercooler and finish it off!
These are exciting times
Also, as a side note:
Corvettes are incredibly simple cars!
Its amazing how few components there actually are under the hood! The entire cooling system is 5 hoses, the engine has 4 grounds, there are 4 or 5 sensors, etc... It is tight and time consuming to get everything hooked up, but the actual parts count is amazingly low when you compare it to anything European
Old Mar 1, 2010 | 02:06 AM
  #35
techvette's Avatar
techvette
What about compared to anything Japanese?
Old Mar 1, 2010 | 08:55 AM
  #36
wooden's Avatar
wooden
6 Hours later:
Now the easy part
hard to believe it took 6 hrs. I did mine in about 20 minutes by myself I actually was suprised how easily it went in.
