From: Greater Detroit Metro MI, when I'm not travelling.
It is coming...
Coming to a street race near you (just kidding! )
Callies Compstar 6.125” H-Beam rods w/ARP 2000 7/16” bolts, Wiseco Forged pistons, tool steel wrist pins and anti friction coating on skirts, Total Seal 1.2 stainless top ring 1.2 napier, 3mm oil ring, Clevite H series bearings:
GM ZR1 camshaft and N Motion 4x Double Roller timing chain, torington bearing and nitrated gears.
very, very nice! i recommend upgrading to a ls7 card style in custom TB to intecooler pipe so you can accuratley tune all the air that bad boy is gonna be pumping. plus it will give you ports for meth!
Originally Posted by Serif
Looks slow Sam lol. You bringing that to Winged Warrior?
You better believe it! This thing is going to FTD in autocross at Winged Warrior! And by FTD I mean DNF every run because it gets no traction before 80MPH Then it will get slaughtered by all the trailer queens on slicks at the drag strip... But in the end I will drive it back 1000 miles to NJ, and life will be great
Nice build. What clutch is that exactly ( street twin carbon, street twin carbon lite, billet carbon twin ( bc2). I'm about to get a clutch and was wondering what your clutch is rwtq rated for. Thanks and good luck with your install.
