Ever wondered if Methanol Injection is worth it?
#61
My car.
Lethal's car
#63
Part of the problem is that most cars capable of trapping 160 don't have the required safety equipment to log enough practice runs to get to that trap.
#64
BTW I just run the correct fuel. No need for meth. At that time it was 109, now I'm trying an E85 setup.
#65
Former Vendor
If it wasn't for meth I would not of been able to run 159+ last weekend in 95+ degree weather weighing 85lbs more than last season with an iron block.
Meth kept my IAT's down to the 120 degree range-without it the IAT's would of been over 200.
Looking to go 162-3 this season.
Meth works-and with a capable tuner-will not harm your car if it fails. At the power levels most guys here are making there is a scheduled maintence that should be followed to make sure everyhting is in working order.
Anything can happen at anytime-just like when your car was stock-just now we don't have a warranty.
#66
Former Vendor
We've tuned many cars with or without methenol. I prefer methenol, can definitely see the difference on our loaded dyno, expecially back to back runs on inlet temp/detenation.
Have a good amount of cars living on methenol systems with some running dual nozzle's full tilt. When we have a engine failure from a methenol problem I'll let you know. Been over 6 years so far.
Got a few road racers running them pretty heavy too(5-8 gallons a day). They report engine coolant temps lower almost 20 degree's when hammering them. Guess the meth has enough cooling to lower engine temp too.
