LS2 engine/cylinder head suggestions
My goal is to have an engine that will easily support 1,000+ rwhp and not be "on edge". It doesn't see the dragstrip, but I do enjoy the Texas 2k-like street stuff. I will say that with my eBoost2, I have multiple boost settings that I can change with the push of a button, so it's not going to be just cruising around town on full-tilt. Not to mention that no cars in my area have this much power, so it's pointless to have around here, but It would be cool to make it out to some get togethers in Texas.
I truly like the idea of the AES 385ci LS2 with the Callies crankshaft, Callies rods, CP pistons, good rings, ARP main studs and head studs.
Some questions I have are these:
Crankshaft: Compstar or Dragonslayer?
Rods: Compstar or Ultra H-beam?
Thoughts on O-ringing the block and heads? Reliability with lots of city driving?
Also, I honestly have no idea on what are the best cylinder heads for 4.0"+ bores without breaking the bank. On a 6-speed turbo car, do the rectangle ports fit better than the cathedral ports? I am a big fan of a thicker deck surface, but I'm not sure I could swing anything as pricy as the AFR/TF/Mast stuff. What are my options as far as best "value" to fit my application?
If I forgot any pertinent information, just post up and I'll answer it.
Ultra H-beams
Those would be on the list if you don't want to be on edge.
Any aftermarket cylinder head with a thick deck will work. The ETP and PI heads are .750" deck. That's a good standard. Oring isn't needed.
I did a little searching this morning to see if I knew you and unless I'm missing something, an RHS based 441, 14:1 CR, E85 build isn't exactly "stock" LOL Very badass nonetheless.
Ive had two cars kill that clutch at the 900-950 rwhp level, so the clutch, injectors, fuelsystem, turbos will all be done at that same time, so thats pretty much the limit, 1000ish rwhp. Turbos will only support 1000-1050 tops, on kill.
I would definitely go the E85 route, but the fuel system is going to cost more than the engine.
Chris
