Notice a subtle difference between the ZR1 and Z06 diff case that will cause some hassles. As you can see in the picture below, the green cirle shows where the z06 case would usually have your differential cooler feed fitting. The line circled in red would usually plug into the case at the bottom.
The ZR1 fitting points toward the sub frame and there is no clearance to squeeze the line between the diff case and sub frame. The ZR1 must have notched the sub frame, or given more clearance in the original casting.
I hate how common small obstructions like that are and how much they can throw a wrench in what is supposed to be a quick and straightforward swap.
Looking at it, you won't likely have room to get a drill at it from a straight-on vector, so you may have use a longer bit to drill through both the front and rear walls of that part of the crossmember. Of course this is predicated upon how much material is in the way at all. The picture doesn't show whether the current boss hangs down far enough for a notching to work, or if it's tucked up high enough to need drilling. Either way, easy fix, and no need to drop the assembly.
Just my thoughts.
09-up stick cars all got a shorter torque tube assembly.... I forgot all about that when we shipped out the diff case. The case must be drilled from the bottom and the rear hole plugged. Call me tomorrow and I will get you the parts needed.
I have seen those brace work soo good it broke the ear of the motor where the scatter shield was bolted to the motor. No problem the tranny was saved and the motor was broken.
Just my thoughts.
Yea, I will be plugging the stock feed pointing toward the subframe, and drill & tap the small fitting into the bottom of the case.
I think I should be ok, I believe the fitting is the same as the small ones on the diff cooler. I will just run down to the local parts store to get a plug for the rear hole. My biggest worry it drilling into the case as I don't want to get filings inside the diff.
I am running an aftermarket block, seems to be a stronger casting. I guess if you aren't breaking parts, you aren't going fast
I'd honestly rather break a block than an expensive-*** built TR6060/ZR1 diff. There aren't too many places to go from that drivetrain. At least if you crack a block, you have an excuse to experiment with more displacement, deck height, etc. If the rotating assembly survives, you can sell that off to recoup funds for more CID and/or compression in your new block.
There's fun in upgrading, not so much in replacing something that's already supposed to be the top of the heap.
I have broke quite a few drive lines as far up as the bell housing, but never seen anyone crack a block
Badass build, I'd love to have all of the C6Z/ZR1 stuff in the back of my car! I had no idea how beefy the ZR1 housing is, that's a nasty piece. I'm jealous of all the DSS guts, too. That stuff is truly nasty.
I'll give you a little heads up as to my experience with that clutch. It was great on the street, but I busted torque tube housings and diff cases semi regularly (I'd break something every 30-40 passes for a while) until I trashed my Spec super twin, and I'm not the only person on here that has had that experience.
My current clutch, even cranked down on the twin sintered iron discs, doesn't lock up as hard as the Spec....and solved all my issues breaking driveline pieces. Getting rid of the Spec was the best investment I've made yet.
I had a custom twin 8.5" sintered iron slipper clutch built. It was done by Rob Youngblood of Advanced Clutches http://www.advancedclutches.com/metalcoverclutches.htm. Its a pricey piece but cheaper than yet another diff.
PM me if you want to know more, I've found it to be street friendly, along with being both measurably faster and far more consistent out of the hole, all while being easier on equipment. Its not really a lot of work if you set it up right (a lot easier than breaking parts) and works well with the QTP bellhousing with some basic machining.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Do you honestly think the brace, which is 4-5' back behind the torque tube assembly broke an ear off your engine?
When did I said my engine broke from a brace????? Maybe you need to read properly before having onething in your mind.
I said I saw a car with an ECS brace broke the ear of his motor where the bellhousing was bolted to the motor. I am only saying what I saw and it was a C5.
My motor is a different situation and maybe you're interested in my theory here about my motor, I have closed that book and enjoying my new power.
I also thought that was what he implied. I will take my chances.
Originally Posted by pamperedcar1
Lb, I hope not but we will see.
DSS makes the best product on the market. You won't need worry about it at all.
Trin, I thought you implied that if the trans/diff don't break, next in line would be the torque tube, bell housing, then motor it self ...
drive shaft is in, just waiting for the SFI bell housing
[IMG][/IMG]
You will need to modify the bell housing before install. If you bolt the slave cylinder on the torque tube, then slide the new bell housing on top of the torque tube, you will see where you need open up the previsions for the slave cylinder lines. Give your self a little extra room so the lines don't rub on the bell housing.
