C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Started my e-force install - question???
Old Nov 6, 2012 | 06:04 PM
Red Sleeper's Avatar
Red Sleeper
Default Started my e-force install - question???
C6 06 A6
Base model
Bone Stock
22,000 miles
Can anybody tell me what the clips are for that go between the frame and subframe?
Old Nov 6, 2012 | 06:26 PM
Motorhead-47's Avatar
Motorhead-47
Originally Posted by Red Sleeper
C6 06 A6
Base model
Bone Stock
22,000 miles
Word has it that in pre-2008 cars the firewall is different..just enough different so that the Edelbrock can contact the firewall. Those parts slightly lower the engine to add clearance. This keeps the supercharger from contacting the firewall. If the supercharger contacts the firewall your interior becomes one big echo chamber for the mechanical noises of the supercharger....not good.
Old Nov 6, 2012 | 06:41 PM
Red Sleeper
I was curious. I thought it might have been hood clearance.
I was a bit worried about getting the crank bolt loose but it turned out not to be a problem at all. I'll pin it tomorrow.
So far so good!
Old Nov 6, 2012 | 08:21 PM
Red Sleeper
This is how I held my crank. Simple and worked great.
http://i145.photobucket.com/albums/r...charger003.jpg
http://i145.photobucket.com/albums/r...charger001.jpg
Old Nov 6, 2012 | 08:28 PM
Motorhead-47
I like it! Simple, low cost and a common tool!
Old Nov 6, 2012 | 08:40 PM
Red Sleeper
I was a little worried about marring the surface of the pulley but there was enough lip to protect it.
Old Nov 7, 2012 | 07:06 PM
Red Sleeper
Thanks for the super picture. I made it to step 123 installing the water pump and couldn't quite figure out how it mounted until I looked at your picture.
Pinning the crank went well but I had to trim off about 2" of length on both the drill bit and the reamer. Glad that is done!
Removing the bracket on the power stearing pump was down right tough. That hose had no intentions of coming off at all.
I was very careful and lined up the template to cut the radiator shroud. I figured it would be perfect - it wasn't. I may have to trim it.
Reading ahead Step #174 has you removing a vacuum cap. Does anything go back on it? I may have missed something. Also do you have any pics of how the wiring harness is laid out?
Old Nov 7, 2012 | 07:51 PM
Motorhead-47
Step #183 talks to the connection to your driver's side valve cover.
Not sure what pics you need of the wiring harness. I may not have what you are looking for. Here are the two that I have that might help.
Dang...you are nearly done!
Old Nov 7, 2012 | 08:06 PM
Red Sleeper
Far from done...
I'm hoping the wiring harness will become obvious as I proceed. I see it now on step 183.
What about that piece you have to grind off on step #155. Is there anything I need to know there?
Old Nov 7, 2012 | 08:15 PM
Motorhead-47
Far from done...
About post #53 in the following link talks to it. Just pull it off, and put your grinder to it. If you don't do this you get a real big vacuum leak!
My buddy "rdodson" in FAIRBANKS ALASKA first tipped me off to the interference issue. He found it before it made the Edelbrock instructions and alerted me.
http://forums.corvetteforum.com/c6-f...-for-me-3.html
Old Nov 7, 2012 | 08:41 PM
Red Sleeper
Thanks, I have ear marked your link.
Had a minor surprise when I started looking around under the car. Not sure when this happened. As far as I know i never hit anything.
http://i145.photobucket.com/albums/r...charger006.jpg
Old Nov 7, 2012 | 08:48 PM
Motorhead-47
Ouch! Hard to tell from the photo...is that upward or backward? Is the neighbor's cat or dog missing?
Old Nov 7, 2012 | 08:55 PM
Motorhead-47
Check the welds....worst case it is about $225.00 and bolts on
http://store.gmpartshouse.com/parts/...agramCallOut=2
Old Nov 7, 2012 | 09:20 PM
Red Sleeper
Actually it's bent straight back and bent perfectly dead center. It looks natural to an untrained eye. It might have been this way when I bought the car. I've had it on a lift a few times but never noticed it but I've always thought the spoiler was wavy. I don't think I'm going to worry about it this go around. I might fiddle with it a little bit before I put the fascia back on; maybe try an pull it back out. The bolt for the heat exchanger still lines up ok.
Old Nov 8, 2012 | 10:47 AM
Red Sleeper
Motorhead 47,
send TPSMAK you address and he will send you a teeshirt - finder's fee!
Old Nov 8, 2012 | 06:34 PM
Red Sleeper
I got to work on it six hours today and made it to Step 159. Yes, I set that heavy SC all by myself... with the help of a hoist which is the only way to go IMO.
The last bolt in the sequence #8 was tough to get a socket on. I used needle nose plyers to get it in far enough to get a socket on it.
The book said to torque the bolts to 7ft lbs. I didn't have anything that went down that low. I used an analog torque wrench and kind of guessed at where the 7 ft lbs. graticle would be. I'm going to re-torque again in the morning just to be safe.
Putting the short hose between the pump and the heat exchanger took some patients. I ended up taking the heat exchange back out to get the hose on it.
Edelbrock did not cap an unused vacuum inlet at the front of the SC. I'm glad I spotted it before it was too late.
The end is in sight!
Old Nov 8, 2012 | 06:36 PM
Red Sleeper
I was able to pull that bar back into shape. No broken welds. The air dam sure looks a lot nicer now.
To Started my e-force install - question???
Old Nov 8, 2012 | 06:37 PM
Motorhead-47
You must not have the NPP/Dual Mode Exhaust. That uncapped port was for the vacuum line to support the NPP optioned cars.
Old Nov 8, 2012 | 06:40 PM
Red Sleeper
That is correct. The book said if I didn't have that vacuum line just leave it capped but there was no cap.
Old Nov 9, 2012 | 03:03 PM
Homeboy77's Avatar
Homeboy77
How are things going? Finished yet?? We look forward to hearing about it.
